JimB
Joined: 25 Aug 2005 Posts: 65 Location: Huntington Beach, CA
Recommendations to work around no serial port |
Posted: Wed Mar 29, 2006 3:05 am |
I want to move the compiler and debugger to my laptop which has no serial port. I want to be able to read the printf statements to check my code. What is the best way to go? I found a small module that will make a USB port emulate a serial port. About $30. Are these things as good as they advertise?
JimB |
jfk1965
Posted: Wed Mar 29, 2006 3:13 am |
I've done exactly the same and I use one of the USB to serial convertors with no problems at all $30 seems a bit steep though, I paid £10 for mine which equates to around $17.
JFK |
arunb
RE: |
Posted: Wed Mar 29, 2006 6:45 am |
Quite right these USB converters are quite handy apart from being cheap.
These converters work exactly like the in built ones.
They also work with ActiveX controls like MSCOMM control.
thanks
arunb |
Mark
Posted: Wed Mar 29, 2006 7:09 am |
However, there are occasions where we have have problems using these devices. Usually this involves timing critical applications. For what you want, they should work just fine. |
