Bootloader
bernardinim
Bootloader
PostPosted: Mon Mar 27, 2006 3:49 am     Reply with quote
Hi, i am trying to use ccs bootloader on my project based on Pic18F2525 @ 32 Mhz (external clock). I want to use pins RB6 and RB7 for dowload the code.... All my trials failed.
What are the step that i have to follow ?
(for example i try to download the code with ccs port monitor and i receive a time out error)...
bernardinim
Bootloader
PostPosted: Mon Mar 27, 2006 9:08 am     Reply with quote
MY CODE:
#include <18F2525.h>
#FUSES WDT1 //Watch Dog Timer uses 1:128 Postscale
#FUSES EC //External clock
#FUSES NOBROWNOUT //Reset when brownout detected
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOFCMEN //Fail-safe clock monitor enabled
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for low-power operation
#FUSES NOMCLR //Master Clear pin enabled
#use delay(clock=32000000)
#use rs232(baud=9600,parity=N,xmit=PIN_B7,rcv=PIN_B6,bits=8)
#define _bootloader
#include <bootloader.h>
#include <loader.c>
#org LOADER_END+2,LOADER_END+20
void application(void) {
while(TRUE);
#org 0x40,0x7F
void main(void) {
if(!input(PIN_B3))
load_program();
application();
#ORG default
#int_global
void isr(void) {
jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
PostPosted: Mon Mar 27, 2006 9:45 am     Reply with quote
You do understand, that the actual 'bootloader', has to be loaded into the chip with a normal programmer, before you can use it?.
bernardinim
bootloader
PostPosted: Mon Mar 27, 2006 9:50 am     Reply with quote
yes.. i know...
It's the first time that i use a bootloader...
What i have to do?
Can u give me a simple example that work.. so i can understand..?
PostPosted: Mon Mar 27, 2006 10:10 am     Reply with quote
Start by getting rid of all your #org statements. You only need include bootloader.h, not loader.c. Loader.c, is the bootloader program itself, which has to already be in the chip (which is why I queried this). Your program, will actually 'sit' at 0x500, and attempting to put part of it below this, will overwrite/destroy the bootloader code that is already there. The build statement in bootloader.h, already re-vectors the interrupt handler as required.
Compile ex_bootloader.c, and put this into the chip. Then compile your program, just as normal, but with bootloader.h included. The 'load' is triggered by pulling B5 low.
bernardinim
bootloader
PostPosted: Tue Mar 28, 2006 1:52 am     Reply with quote
Using ccs serial port monitor i receive the error Timeout when downloading ....
I use these port setting (9600,n,8,1 with no software flow control), It's correct?
I not know if the problem is in serial connection during downloading application or in the bootloader....
Please help me.....[/b]
Christophe
PostPosted: Wed Aug 09, 2006 3:39 am     Reply with quote
Is there another way to trigger the bootloader program? Eg. a special character on the serial port like '@' or so?
Being triggered by pulling B5 low is a hardware issue, difficult to do that.
