ADC conversion question
wolverine_349
PostPosted: Fri Mar 24, 2006 5:05 am     Reply with quote
I am using the 10bit ADC off the 16f689 for some simple conversion and this is what i get:
actual analog voltage off mutimeter=0.65V
reading from the adc =0.5674V
if analog=0.66V,digital =0.57V
and if the anlog voltage increases the digital value goes far and far from the anlog value
this is how i interprete the voltage off the ADC code
//max adc voltage is 4.5V(MAX_VOLTAGE)
long y;
float decivolts;
         GO=1;                     //start conversion
      while(GO)continue;            //poll GO for cobversion completion
      ADIF=0;
               y=Read_ADC(ADC_READ_ONLY);
 decivolts=(y*MAX_VOLTAGE)/1023;
also,if i take many samples,analog voltage remains the same whereas the digital value changes at times.
is the formula ok? what am i doing wrong? need help guys.
Storic
PostPosted: Fri Mar 24, 2006 5:24 am     Reply with quote
I am also reviewing my analogue coding, I had lots of movement where I was getting different reading all the time from the same ref input. Have you considered http://www.ccsinfo.com/forum/viewtopic.php?t=19509 Filtering your analog input with code as describe.
Andrew
What has been learnt if you make the same mistake? Wink
SherpaDoug
PostPosted: Fri Mar 24, 2006 8:06 am     Reply with quote
I would first print out the A/D reading in hex and make sure that is stable and tracks the analog input. Once you know that works then you can worry about the math.
On the other hand "decivolts=(y*MAX_VOLTAGE)/1023; " looks bad to me. If y is a long int then I would expect y*MAX_VOLTAGE to do an integer multiply, effectively truncating MAX_VOLTAGE to 4. The /1023 may also be an integer division, the list file will tell you for sure.
