oscarec60
Joined: 23 Mar 2006 Posts: 3 Location: Caracas, Venezuela
I have problems with port D for pic18f4620 PLEASE HELP!!!!!! |
Posted: Thu Mar 23, 2006 8:54 am |
I am programming the Pic18f4620 I have PCWH 3,203 and Plug-in of Mplab, and need to use port D for some things. I finish registering in the forum to request aid. Annexed I leave them I cosay that by very simple that it seems has errors and I have not been able to use port D that as much I need. Thank you very much reason why they
#include <18F4620.h>
#device adc=8
#fuses NOWDT,WDT128,HS, NOPROTECT, IESO, BROWNOUT, BORV21, NOPUT, NOCPD, NOSTVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, NOFCMEN, NOXINST, NOPBADEN, NOLPT1OSC, NOMCLR
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
while (1)
output_d(0x00);
output_d(0x3f);
Posted: Fri Mar 24, 2006 12:43 am |
Maybe output_d() doesn't work on your version of the compiler.
I don't know, I don't have that version to test.
Try doing it this way:
Set the TRIS for Port D to be all output pins. Then write directly
to the Port D register. See the lines shown in bold below.
Quote: | #include <18F4620.H>
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay (clock=20000000)
#byte PortD = 0xF83
set_tris_d(0x00);
while (1)
PortD = 0x00;
PortD = 0x3F;
