Storic
Joined: 03 Dec 2005 Posts: 182 Location: Australia SA
lost my code's on new install |
Posted: Wed Mar 22, 2006 5:14 pm |
I installed the new version over my older version and found that all of my files and programms that were within the CCS folder were deleted with the new version (V3.248).
I can only say that I had backed up the CCS directory the day before. I still had everything minus some changes.
I now have a seperate directory that is not within the CCS directory for all of my codes.
Andrew ![Confused](images/smiles/icon_confused.gif) _________________ What has been learnt if you make the same mistake? ![Wink](images/smiles/icon_wink.gif) |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Posted: Wed Mar 22, 2006 7:28 pm |
I've had that technical support phone call before...
![Very Happy](images/smiles/icon_biggrin.gif) _________________ I came, I saw, I compiled. |
Humberto
Posted: Wed Mar 22, 2006 8:17 pm |
This type of errors is recurrent. This would be avoided if during the installation,
the new folder name by default instead of PICC as always, it could be PICx.xxx
being x.xxx the version ID.
Humberto |
Posted: Wed Mar 22, 2006 9:02 pm |
Is this a real problem with vs. 3.248 or is this a user error ?
I haven't had any problems with previous versions of CCS.
All my projects are stored within the CCS directory, like this:
C:\Program Files
-----\Picc
--------\Projects
-----------\Tachometer
-----------\Game Controller
-----------\Flex_lcd
etc. |
Are you saying that if I install vs. 3.248, then all my project files
will be deleted ? |
Storic
Posted: Thu Mar 23, 2006 1:11 am |
I never had a problem before until now, however now I think it is wise to keep the projects coding out of a directory that gets updataed (just in case)
Code: | C:\Program Files
-----\Picc
--------\examples
-----------\Test AD
-----------\input output
-----------\etc
--------\Projects
-----------\Airlock
-----------\AC Control
-----------\Multi IO Function
etc. |
this is simular to what i had at the time, yes this could be some human error I found that as my licence for updated had expired, I am in the process with purchaseing a new 1 year mainenance. (when the log on gets sorted out)
Andrew _________________ What has been learnt if you make the same mistake? ![Wink](images/smiles/icon_wink.gif) |
Darren Rook
Posted: Thu Mar 23, 2006 9:10 am |
The CCS installer doesn't delete any files in the target directory. _________________ I came, I saw, I compiled. |
Posted: Thu Mar 23, 2006 2:11 pm |
I backed up my entire PICC directory on a CD-ROM, and then
installed version 3.248 of the PCM and PCH command-line
compilers. It didn't affect my source files at all. They are
still there. So I don't see any problem. |
Storic
Posted: Thu Mar 23, 2006 2:39 pm |
I have redone a install to verifie and will yealed to the consenses, No additional files were deleted. Sorry for the inconvieience, ![Embarassed](images/smiles/icon_redface.gif) _________________ What has been learnt if you make the same mistake? ![Wink](images/smiles/icon_wink.gif) |
