Problem with the ICD flag
berberis
PostPosted: Tue Feb 07, 2006 9:55 am     Reply with quote
I wrote the test program:
#include "18f6622.h"
#device *=16
#fuses PROTECT=15
#fuses WRT=15
#fuses EBTR=15
main()
When compiled this gave the listing:
CCS PCH C Compiler, Version 3.235, 27782               07-Feb-06 15:24
               Filename: C:\ccstest\main.LST
               ROM used: 26 bytes (0%)
                         Largest free fragment is 65510
               RAM used: 5 (0%) at main() level
                         5 (0%) worst case
               Stack:    0 locations
0000:  GOTO   0004
....................  #include "18f6622.h"
....................  //////// Standard Header file for the PIC18F6622 device ////////////////
.................... #device PIC18F6622
.................... #list
.................... #device *=16....................
.................... #fuses PROTECT=15
.................... #fuses WRT=15
.................... #fuses EBTR=15
.................... main()
0004:  CLRF   FF8
0006:  BCF    FD0.7
0008:  CLRF   FEA
000A:  CLRF   FE9
000C:  MOVF   FC1,W
000E:  ANDLW  C0
0010:  IORLW  0F
0012:  MOVWF  FC1
0014:  MOVLW  07
0016:  MOVWF  FB4
0018:  SLEEP
Configuration Fuses:
   Word  1: 0F00   NOIESO NOFCMEN RESERVED
   Word  2: 1F1F   BROWNOUT WDT BORV25 NOPUT WDT32768
   Word  3: 81F3   CCP2C1 NOLPT1OSC MCLR RESERVED
   Word  4: 0085   STVREN NODEBUG LVP NOXINST BBSIZ1K RESERVED
   Word  5: C00F   NOCPD NOCPB
   Word  6: E00F   NOWRTD NOWRTC NOWRTB
   Word  7: 400F   NOEBTRB
Which is what I expected, I changed the #device line to
#device *=16  ICD=TRUE
This changed the Configuration Fuses section to
   Word  2: 1E19   NOBROWNOUT NOWDT BORV25 NOPUT WDT32768
   Word  4: 0000   NOSTVREN DEBUG NOLVP NOXINST BBSIZ1K RESERVED
   Word  5: C0FF   NOPROTECT NOCPD NOCPB
   Word  6: E0FF   NOWRT NOWRTD NOWRTC NOWRTB
   Word  7: 40FF   NOEBTRB NOEBTR
This causes problems when I try to download the code to an ICD-U40 as in the 6622 the last 3 configuration words have only 4 bits in lower byte so the download fails as the actual configuration fuses dont match the fuses generated by the compiler.
Any ideas?
rwyoung
PostPosted: Tue Feb 07, 2006 1:34 pm     Reply with quote
Are you sure
#device *=16
is necessary for the PIC18F6622?
Rob Young
PostPosted: Tue Feb 07, 2006 5:50 pm     Reply with quote
I compiled your program with PCH vs. 3.242, and I got this result:
   Word  5: C00F   NOPROTECT NOCPD NOCPB
   Word  6: E00F   NOWRT NOWRTD NOWRTC NOWRTB
   Word  7: 400F   NOEBTRB NOEBTR
Here is the Config Bits line from the HEX file. I added spaces
in between the words to make it easier to read. It looks OK.
:0E000000 000F 1F1F F381 8500 0FC0 0FE0 0F40 9F
So it's probably just a problem with your version.
PostPosted: Wed Feb 08, 2006 2:16 am     Reply with quote
You can fix this yourself by changing the chip configuration using chipedit.exe in the PICC directory.
I compared Chipedit.exe for the 18F6622 in v2.235 and v2.241 and noticed some differences. Change chipedit.exe to the settings below and you should be OK.
PROTECT   00FF 0000 5
NOPROTECT 00FF 000F 5
WRT       00FF 0000 6
NOWRT     00FF 000F 6
EBTR      00FF 0000 7
NOEBTR    00FF 000F 7
Sigma
PostPosted: Thu Mar 23, 2006 5:15 am     Reply with quote
Hi, ckielstra or any other friend with latest compiler,
Could you please kindly check for me the value for NOWRTC amd NOWRTD for device 18F6622?
I got some error for these two configurations also.
Thanks.
Sigma
PostPosted: Thu Mar 23, 2006 6:09 am     Reply with quote
Is it perhaps probable that the problem is caused by putting numeric values after the fuses?...
The effect of this will be 'undefined', and is not legitimate CCS code.
PostPosted: Thu Mar 23, 2006 6:46 am     Reply with quote
From a post in another thread I understand you are using v3.236.
The settings for NOWRT and NOWRTD in v3.236 are equal to v3.245, when you compare these settings to the datasheet they seem correct.
PostPosted: Thu Mar 23, 2006 7:44 am     Reply with quote
This is another example of new extensions to the compiler nowhere mentioned in the release notes.
Sigma
PostPosted: Thu Mar 23, 2006 8:09 am     Reply with quote
Thanks Ttelmah & ckielstra,
First of all, i did not place numeric values after the fuses in my test program. But i tried to do it also. The results are the same.
I did try just a very simple program like
#device ICD=TRUE
#fuses HS, NOWDT
output_high(PIN_A1);
Initially there is problem of programming it into the chip. The problem is that after programming process, there is a window popping up, indicating some mismatch of the actual and expected configuration bits. But after using the chipedit technique as ckielstra mentioned, it can be programmed and working properly for this simple program. However, when I tried to use the debug mode, it prompts 'The detected target name:PIC18F6622 does not match the code's target: PIC16C622. Do you want to continue' as i also mentioned in the other link http://www.ccsinfo.com/forum/viewtopic.php?t=26463
So from what i tested today, i would say after the chipediting, it improve the programming process, but not for the debugging.
Why i said 'improve'? Because my colleague just found that it is still having problem of burning in the code while come to a more complex code. The process repeated, but the mismatch of the configuration bits are NOWRTC and NOWRTD. Sorry i could not paste the complete code here as it is too lengthy. Actually this is a code migration process from 18F452 to 18F6622. And we did not expect so many problems.
Dear friends, could we say that this is due to older compiler version? Do you foresee I will get into the same problem when i change the mcu to 18F6627? I think so. But not very sure.
Could we solve it by using the latest version. I do not know.
Please help!
Sigma
PostPosted: Thu Mar 23, 2006 8:21 am     Reply with quote
Sorry, but the ability to put a number for some things is mentioned, but I don't think the 6622, allows four bits for all three values. I don't know what the effect of setting a config bit that is not supported would be, but it looked like a likely thing to confuse the configuration bits...
PostPosted: Fri Mar 24, 2006 4:01 am     Reply with quote
You are right, I missed this addition to the October 2005 PICC manual. The version 3.226 I'm using doesn't support this feature, v3.236 does. What I don't like is that new features like this are nowhere mentioned. Not in the PICC release notes or readme.txt.
The 6622 supports 4 bits for PROTECT, EBTR and WRT, so setting these fuses to a value of 15 as Sigma does is valid.
