| data logger |
Posted: Wed Mar 22, 2006 9:06 am |
My current project involves a pic mcu based datalogger. So far the simple code initially detects a passing object and when high a count is incremented on a seven seg display. The code is as follows:-
SAQlab6: To make the 2-digit 7-segment display count
up from 00 through 99 when object passes sensor
#include <16f877.h>
#use delay(clock = 4000000) /* Tell compiler using a 4MHz crystal */
#fuses XT,NOWDT,NOPROTECT,PUT,NOLVP
#byte PORTD = 8 /* PortD is at File 8 */
#byte PORTA = 5 /* PORTA is at File 5 */
#bit DIGIT_L = PORTA.2 /* Least significant digit enabled by RA2/TR_Q2 */
#bit DIGIT_H = PORTA.3 /* Most significant digit enabled by RA3/TR_Q1 */
#bit SW_FIVE = PORTA.0 /* Set up porta.0 to SW_FIVE */
int const svn_seg[16]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
main()
int loop_count=0, left_digit, right_digit, number=0;
set_tris_d(0x00); /* Set port D to be outPuts */
set_tris_a(0xF3); /* Set PORTA bits 3 & 2 to be outputs */
setup_adc_ports(NO_ANALOGS); /* Make PortA all digital, no analog inPuts */
left_digit = number/10; /* The Tens digit */
right_digit = number%10; /* The remainder after div by ten is the Units digit */
if((loop_count & 1) == 1) /* Test if millisecond count odd or even; if even skip to the else*/
DIGIT_H=0; DIGIT_L=1; /* Switch left 7-seg display on and the other one off */
PORTD=svn_seg[left_digit];/* This picks up the nth value of the array of 7-segment codes */
DIGIT_H=1; DIGIT_L=0; /* Switch right 7-segment display on and the other one off */
PORTD=svn_seg[right_digit];
delay_ms(4); /* 4-ms delay */
if(SW_FIVE == 0) /* IF SW = 0 IE ON */
number++; /* Increment the main display count */
if (number == 100) number = 0;
delay_ms(4); /* Debounce */
while(SW_FIVE == 0) ; /* Wait until switch is released */
loop_count++;
} /* End of while loop */
} /* End of main() */
The next stage is to gather a real time in between the detection of each passing object. Timer 0 would probebly be the best option so i was thinking something along the lines of
#define INTS_PER_SECOND 76 //(20000000/(4*256*256))
byte seconds; //Number of interrupts left b4 1sec elapsed
#int _rtcc
clock_isr() {
if{--int_count==0) {
++seconds;
int_count=INTS_PER_SECOND;
main() {
byte start;
int _count=INTS_PER_SECOND;
set_rtcc(0);
setup_counters (RTCC_INTERNAL, RTCC_DIV_256);
enable_interrupts (INT_RTCC);
enable_interrupts (GLOBAL)
I was wondering if this could be implemented to the code i have written or would there be a simpler or easier method of doing so. |
wise up son Guest
| data logger |
Posted: Wed Mar 22, 2006 9:36 am |
| ill give u some code if i can get something back |
jonboy
Posted: Thu Mar 23, 2006 5:59 am |
| like wat? If i can..... |
