pasini
Joined: 12 Dec 2005 Posts: 50 Location: Curitiba - Brazil
Bootloader + RS232 (HyperTerminal ?) |
Posted: Wed Mar 22, 2006 6:32 am |
Hi all,
What program can I use to download .hex file with bootloader.c and loader.c ? Is it possible to use Hyperterminal from Windows ?
RS232 must be used.
I want to download a long file to EXTERNAL FLASH PROGRAM memory. But I cannot download the file straightforward because I think bootloader cannot handle that big amount of data to be programmed. So bootloader must ask for furhter data when it is ready, but can Hyperterminal work like this ?
I am using PIC18F8680 external flash program memory AM29F800B MPLAB7.31 and CCS 3.241.
I plan to use the Extended Microcontroller Mode (EMCU).
Thanks in advance for any help.
Pasini |
jma_1
Posted: Wed Mar 22, 2006 7:41 am |
Greetings,
I believe HyperTerminal will work to download a hex file (Transfer->Send Text File).
HyperTerminal does not have any kind of programming interface. Trying to include a protocol into it, without user interaction does not seem possible.
How about sending a command from the embedded code signalling loading of external flash memory? (then user selects additional code to download).
Another option would be to create your own loader application which controls a serial port. I remember seeing a post with VB code which could be a template for your application.
Cheers,
JMA |
pasini
Posted: Wed Mar 22, 2006 8:35 am |
What do you mean by Quote: | command from the embedded code signalling loading of external flash memory | ?
If bootloader asks for more data then I cannot use the bootload.c and loader.c, alright ?
I think I will create my own Windows app to download the file. I have some apps almost ready for use.
Pasini |
Mark
Posted: Wed Mar 22, 2006 8:47 am |
Do anyone ever read the comments (or code) in the files?!!
//// This program uses the loader driver to show how you can ////
//// read and write to an internal program memory. ////
//// The LOADER.C will take an Intel 8-bit Hex file over RS232 ////
//// and modify the flash program memory with the new code. ////
//// After each good line, the loader sends an ACK character. The ////
//// driver uses XON/XOFF flow control. Also, any buffer on the PC ////
//// UART must be turned off, or to its lowest setting, otherwise it////
//// will miss data. ////
//// A program such as Hyper-Term may be used to simply transmit the////
//// .HEX file output from the compiler. ////
Obivously the loader.c file is intended to write to the internal program memory so you will have to modify it to write to your external flash. Don't expect to find an example that will work for you. You are going to have to do some code writing to get what you want. The loader.c would be a good start since it handles the RS232 and hex files. |
pasini
Posted: Wed Mar 22, 2006 2:30 pm |
Yes, I got it. RTFDS (read the [censored] data sheet !!!!!!!)
Hyperterminal will transmit the .hex as I want.
But now the problem is with the code I want to write in the external memory, which begins at 0x10000.
Why the following code does not compile, since it is intended to be entirely in the external memory ?
In the internal memory I have the bootloader and in the external memory I want my application, which begins at 0x10000.
The error is INVALID ORG RANGE. Why is that if I have 512kwords memory ?
#include "18f8680.h"
#device *=16 ADC=10
//#fuses HS,NOWDT,NOPROTECT,NOLVP
#fuses HS,NOWDT,NOPUT,NOPROTECT,BROWNOUT,NOLVP,NOCPD,NOWRT,EMCU//,WAIT //,NODEBUG
#use rs232(stream=RS232,baud=9600,xmit=PIN_C6,rcv=PIN_C7,parity=N,bits=8)
//#use FAST_IO (C)
#case
#define BASE 0x010000
#define BUZZER PIN_C2
#define LigaBuzzer() output_high(BUZZER)
#define DesligaBuzzer() output_low(BUZZER)
#org 0x10000
void retorno_isr(void)
/* #asm
MOVFF 0F,00
MOVFF 10,01
MOVFF 11,02
MOVFF 12,03
MOVFF 13,04
MOVFF 0D,FE9
MOVFF 08,FEA
MOVFF 09,FE1
MOVFF 0A,FE2
MOVFF 0B,FD9
MOVFF 0C,FDA
MOVFF 14,FF3
MOVFF 15,FF4
MOVFF 16,FFA
MOVFF 05,FE8
MOVFF 07,FE0
MOVFF 06,FD8
RETFIE 0
#endasm
#org 0x10100, 0x101FE
void TIMER0_isr(void)
#asm
goto 0x10000
#endasm
#org 0x10200, 0x102FE
void TIMER2_isr(void)
#asm
goto 0x10000
#endasm
#org 0x10300, 0x103FE
void main2(void)
LigaBuzzer();
delay_ms(25);
DesligaBuzzer();
delay_ms(25);
