LCD420 Question
physiks
LCD420 Question
PostPosted: Tue Mar 21, 2006 8:27 pm     Reply with quote
Does anyone know why LCD420.C works beautifully on PIC16F devices and not at all on PIC18F devices?
Eric
PostPosted: Tue Mar 21, 2006 9:25 pm     Reply with quote
#byte lcd = 6    // This puts the entire structure
                 // on to port B (at address 6)
The register addresses are different between the 16F and 18F devices.
Download the data sheet for your PIC. Look in the Table of Contents
on the left side in the Acrobat reader. Find the register map table.
Then look up the address for the Port B register, and substitute that
address for the value of 6, above. This assumes that you have wired
your LCD to Port B.
Data Memory Organization
--- SPECIAL FUNCTION REGISTERS
------ SPECIAL FUNCTION REGISTER MAP
physiks
LCD420 Question
PostPosted: Wed Mar 22, 2006 6:29 am     Reply with quote
That worked, Thanks.
Eric
