Problem with ltc1298 and comparator interupt
Sophi
PostPosted: Tue Mar 21, 2006 8:09 pm     Reply with quote
Hi- I started with the following code- it is a comparator interrupt on PortA . Pins A0, A1 wired together to a pushbutton switch. It works reliably.
#include <16F877A.H>
#fuses HS,NOWDT,NOPROTECT, PUT, BROWNOUT, NOLVP    // HS for 20 mHz, fuses specific to chip
#use delay(clock=20000000)                           // adjust for resonator frequency
#use i2c(Master, SDA=PIN_C4, SCL=PIN_C3)           // set up options
#include <LCD_16f877A.c>
#include <ltc1298_sk.c>
#include <24128.c>                                 // try removing
#use fast_io(c)
#use fast_io(a)
#use fast_io(b)
#include <stdlib.h>
#byte PORTB=6
//this is the one that works
#INT_COMP
comp_isr()  {
    delay_ms(25);  //debounce
    printf(lcd_putc,"\fInterrupt loop ");
void main()   {
 init:
   set_tris_a(0b00000011);             // sets PORTA
   set_tris_b(0x00);
   set_tris_c(0b00110111);             // set all PORTC, pin_C1 in for marry
   lcd_init();
   lcd_putc("\nLucky13");
   setup_comparator(A0_VR_A1_VR); // Mode 2 -A0, A1 inputs to
                                                      // 2 comparators, compare with Vref
   setup_vref(VREF_HIGH|2);            // (mode|value) 5*value/32+1.25=vref
                                                    // value = 2, vref = 1.56V
   enable_interrupts(INT_COMP);
   delay_ms(2000);
   adc_init();
   delay_us(10);
         lcd_putc("\fMain loop");
Then using the CCS driver for the ADLTC1298, I changed the pinouts to
#define ADC_CS   PIN_A3
#define ADC_CLK  PIN_E0 // output from MP
#define ADC_DIN  PIN_E2 // output from MP
#define ADC_DOUT PIN_E1 // input to MP
and the delays in the driver to "delay_cycles(1);"
I think my wiring is OK.
I added (tested and working) code to the one above:
#fuses HS,NOWDT,NOPROTECT, PUT, BROWNOUT, NOLVP    // changed to HS for 20 mHz
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
#use fast_io(e)
#include <stdlib.h>
#byte PORTB=6
//function to use variable 16 bit delay...are you reading this PCM? I owe you bigtime for this function!!
void long_delay_us (long int count)
char i;
i = (char)(count >> 8);                          // typecast count >>8 (right shift count) as char
while(i >= 1)                                        // loop while i >= 1
i--;
delay_us(248);                                     // delay 253 us, adjustable
restart_wdt();                                      // restart watchdog timer
delay_us((char)count);                             // use built-in function delay_us to typecast count
#INT_COMP
comp_isr(){
   int i = 0;                                // loop count
   float ad12, ad12temp;                     // digital output of a/d channel 0 (light)
                                             // digital output of a/d channel 1 (temp sensor)
   long int count;
   set_tris_a(0b11110011);                   // sets port a direction 0=out 1=in
   set_tris_b(0x00);
   set_tris_c(0b00110011);                   // set all PORTC, pin_C1 in for marry
   set_tris_e(0b11111100);                   // set all PORTE, pin_C1 in for marry
init:
   lcd_init();
   lcd_putc("\fFab 15  ");                 // welcome
   adc_init();
   do{
      ad12 = read_analog(0) >> 4;                  // get a/d value (channel 0) and shift
      ad12temp = read_analog(1) >> 4;              // get a/d value (channel 1) and shift
      lcd_gotoxy(1,1);                             // start at 1st line
      printf(lcd_putc,"AD = %5.0f", ad12);         // print to LCD
      delay_us(1500);
        for (i=1; i<=100; i++)                     // start of light sensor action
         count = ((0.244*ad12)+1000);              // y=mx+b-function to relate ad12 and servo 1000us - 2000us
                                                   // b = 1000, m = .244, for light sensor
         output_high (PIN_C2);                     // servo out high
         long_delay_us (count);                    // function call allow 16 bit us
         output_low (PIN_C2);                      // servo out (off)
         long_delay_us (22000-count);
        }//end of for
       lcd_gotoxy(2,2);                            // start at 2nd line
       printf(lcd_putc,"\nTemp = %5.0f", ad12temp);// print temperature sensor reading to LCD
       delay_us(750);
      }while(1);                                   // while true
On startup, the code goes straight to the interrupt loop. When I reset, the software runs in the main loop and interrupts when I push the button. But then it hangs in the interrupt...forever....until I push the button again and it goes back to main. I can push the button over and over and flip back between threads.
I have no experience with interrupts and am at a total loss for what is wrong.
Another wierd thing is that the A/D works great but there is no signal on the clock pin (7 on A/D, 8 on MP). Unless I have a bad probe...
Thanks muchly for any help-
SophE
PostPosted: Tue Mar 21, 2006 8:17 pm     Reply with quote
Read this thread, which talks about clearing the "mismatch"
condition in the comparator interrupt routine:
http://www.ccsinfo.com/forum/viewtopic.php?t=22641
