PCH, PCM and PCB Compiler Installation
prayami
PostPosted: Tue Mar 21, 2006 7:02 pm     Reply with quote
Hi...I got followig CCS compiler version.
PCH 3.235.23.16
PCM 3.206.0.0
PCB 3.239.11.15
The problem is, if I have installed PCH compiler last. And If I try to run
the program for any processor that PCB support then It shows error that
device not supported. If I re-install the PCB compiler then it is compiling
fine.
Vice versa for all the three compilers. Which ever is installed last. That is
the current compiler and the program can not compiler for other two's
processors.
So I have to re-install the compiler everytime if I change the processor
family. I can't understand whether it is a bug or what?
Thanks...In advance......
PostPosted: Tue Mar 21, 2006 8:11 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=24224
