maximum value stored in a float
DSF
PostPosted: Tue Mar 21, 2006 5:03 pm     Reply with quote
Hello;
I'm trying to store values in a float variable. The my problem is that the maximum value I can store is 1410.065408 when I need to store values till 9999.99.
Any help around?
Tks
PostPosted: Tue Mar 21, 2006 5:12 pm     Reply with quote
I’m trying to store values in a float variable. The my problem is that the
maximum value I can store is 1410.065408 when I need to Store values
till 9999.99.
In the program below, the 'value' variable is set to 9999.99 and
the printf statement displays this:
Value = 9999.99
#include <16F877.H>
float value;
value = 9999.99;
printf("Value = %7.2f", value);
This was compiled and tested with PCM vs. 3.245.
DSF
PostPosted: Tue Mar 21, 2006 5:27 pm     Reply with quote
ok
I'will try again despine I'm using ver 3.236
Tks
Daniel Fernandes
