weg22
| Can't output on PIN_B3 ===> CCP problem |
Posted: Tue Mar 21, 2006 12:55 pm |
Hi all,
I am using a PIC16F87 which has an option to use either PIN_B0 or PIN_B3 for the CCP interrupt. I am not using PIN_B3 for CCP, but do need to use it as an output pin. All I am trying to do is output_high on PIN_B3 and it's not working. I tried using the #fuses CCPB0 declaration, but that doesn't seem to be working either. I can successfully output on all other pins (I haven't tried B0) except for B3. My code is attached below. Thanks in advance!
#include <16F87.H>
#include <stdlib.h>
#fuses HS,NOWDT,NOPROTECT,PUT,CCPB0
#use delay(clock=10000000)
main()
SET_TRIS_B(00010011);
output_high(PIN_A2); delay_ms(1500);
output_low(PIN_A2);
output_high(PIN_B2);
output_high(PIN_B3);
output_high(PIN_B5);
output_high(PIN_B6);
output_high(PIN_B7);
} // end of main
Posted: Tue Mar 21, 2006 12:58 pm |
This is a FAQ question. Look in the CCS FAQ, here:
http://www.ccsinfo.com/faq.php
In the Input/Output section, read the question on:
Why isn't PortB, pin 3, working? |
