cwf713
pointers to struct? |
Posted: Tue Mar 21, 2006 9:39 am |
Hello all,
I am migrating from 16F877 to 18F4525 and am having trouble with code that reads a data structure from data eeprom. I am using PCH v 3.6.0.98 and I get the error "invalid type conversion" when compiling the following code:
#define data_size 12 // the number of bytes of data contained in the struct.
struct data
long magicnum;
signed level;
signed gain;
signed long ref_os;
int ext_ref_freq;
int address;
signed ref_state;
short other;
short remote;
short rs485;
short extref;
short rs422;
short rs232;
short ref_int;
short ref_ext;
short ref_auto;
short dummy1; //not used for anything, allows us to have an even amount of memory.
short dummy2; //not used for anything, allows us to have an even amount of memory.
short dummy3; //not used for anything, allows us to have an even amount of memory.
short dummy4; //not used for anything, allows us to have an even amount of memory.
short dummy5; //not used for anything, allows us to have an even amount of memory.
short dummy6; //not used for anything, allows us to have an even amount of memory.
short dummy7; //not used for anything, allows us to have an even amount of memory.
int chksum; //data checksum - equal to everything in the struct except this number
// mod 255.
struct data current_data;.
void data_startup(void)
struct data *tmp;
int magicnuml,magicnumh;
char magicnum[2];
long int i;
short rewrite = 1;
magicnuml = read_eeprom(0);
magicnumh = read_eeprom(1);
magicnum[0] = magicnuml;
magicnum[1] = magicnumh;
if((magicnuml == 0x4A) && (magicnumh == 0x53)) // if good data is stored in the eprom, lets get it and use it.
rewrite = 0;
tmp = ¤t_data;
for(i = 0;i < data_size;i++)
tmp[i] = read_eeprom(i);
if(chksum() != current_data.chksum) // checksum failed, rewrite eeprom
rewrite = 1;
if(rewrite) // if the eeprom doesn't do it for us, lets go with a resonable set of defaults.
current_data.magicnum = 0x534A;
current_data.level = 10;
current_data.gain = 0;
current_data.ref_os = 0;
current_data.ext_ref_freq = 10;
current_data.address = 0;
current_data.ref_state = 0;
current_data.other = 1;
current_data.remote = 0;
current_data.rs485 = 0;
current_data.extref = 0;
current_data.rs232 = 1;
current_data.rs422 = 0;
current_data.ref_int = 1;
current_data.ref_ext = 0;
current_data.ref_auto = 0;
current_data.chksum = chksum();
write_data_eeprom();
temp_data = current_data;
void write_data_eeprom()
long int i;
struct data *tmp;
tmp = ¤t_data;
for(i = 0; i < data_size; i++)
write_eeprom(i,tmp[i]);
The tmp[i] = read_eeprom(i); line causes an invalid type conversion but
the write_eeprom(i,tmp[i]) line does not. This code worked fine with my old PCM compiler for the 16F877. Any thoughts or ideas are much appreciated. |
Posted: Tue Mar 21, 2006 10:24 am |
The read and write eeprom functions for the 18f4525, require a long address (because there is 1K of eeprom). This may be causing the problem. Try manually casting 'i' to a long, or using a long variable to hold this value.
cwf713
Posted: Thu Mar 23, 2006 8:10 am |
Thank you for the response. I changed the line "struct data *tmp" to "int *tmp" and the code compiled with no errors. However, the eeprom did not work until I disabled interrupts while writing to it (as per the 18F4525 data sheet).
Cheers |
