Guest Guest
strstr works on 3,225 but on 3.245 not |
Posted: Sat Mar 18, 2006 8:28 am |
Anybody now why this code work compiled with 3.225, but 3.245 not !?!
I use this on 18F2620, Mplab 7.31
strcpy(buff1, "ende");
printf("Start \r");
while( TRUE ){
gets(buffer);
if( strstr(buffer, buff1) )
printf("---> %s\r", buffer);
printf("Ende Test\r"); |
Posted: Sat Mar 18, 2006 12:50 pm |
You didn't post a test program so I made one. I compiled it with
PCH vs. 3.245.
I don't have your hardware so I used the MPLAB simulator (vs. 7.20).
I commented out the gets() line, and instead I loaded the "buffer"
array with a string.
The following program works OK in the MPLAB simulator using
"UART1" to display RS-232 output in the Output Window.
It displays this:
Code: | #include <18F2620.H>
#include <string.h>
char buff1[50];
char buffer[50];
strcpy(buffer, "This is a test ende"); // Added this line.
printf("Start \r");
while( TRUE ){
//gets(buffer);
