frequency counter using 16f876
hank
PostPosted: Thu Mar 16, 2006 8:07 pm     Reply with quote
hey guyz
pls hel,me using 16f876 as freq counter for measuring freq upto 15 khz
dun wid d programmin,used the same one which mike had posted it got compiled error free,now plzzzzz guyz telme wht to do me using a hall effect sensor,wht wud b the external circuitry required for connecting the hall sensor n interfacing it wid d pic,i mean wht pin connections,crystals,resistances etc.etc. wud have to b used,plsss guyz help me out any1 of u
waitin to hear frm u sooooooon
Humberto
PostPosted: Thu Mar 16, 2006 9:33 pm     Reply with quote
hey guyz
hey man
Ths is a forum, its not a chat. Pls cud u wrte plain English, there ar many rdrs in diz forum
tht dont have English as natural language, plzzzz... Cool
Humberto
Mark
PostPosted: Thu Mar 16, 2006 10:10 pm     Reply with quote
This is also not the place to get your school assignments completed for you.
PICoHolic
PostPosted: Fri Mar 17, 2006 6:46 am     Reply with quote
Come on guys, take it easy on him!!
Let me give you a hint, hank:
Use the Input Capture Module (CCP)
Good Luck
Mark
PostPosted: Fri Mar 17, 2006 7:04 am     Reply with quote
He is using someone else's code. He has no idea how to connect what he has to make it work. Why, cause he isn't doing any of the real work. We shouldn't take it easy on him. Undoubtly this is a school project where he is supposed to be learning something.
SherpaDoug
PostPosted: Fri Mar 17, 2006 8:19 am     Reply with quote
1) Do your best to use proper English spelling and grammar. If English is not your primary language we can make allowances for grammar but your spelling should be reasonable.
2) RTFM... or in this case Read The Fine hall effect sensor Datasheet. I am sure it shows how to connect the sensor to a logic level input. Since there are many types of hall sensors we can't help you without a manufacturer and part number.
Humberto
PostPosted: Fri Mar 17, 2006 10:50 am     Reply with quote
Hi hank,
Firstly it wanted that you know that my previous commentary did not want to be
offensive, I only wanted to put a humor touch to him, but surely you understood
the message that was very well said by SherpaDoug:
"Do your best to use proper English spelling and grammar"
Regarding your question, in the following links you will find usefull info from where
you can learn.
http://ww1.microchip.com/downloads/en/devicedoc/41214a.pdf
http://www.elecdesign.com/Articles/Index.cfm?AD=1&ArticleID=8513
http://www.ccsinfo.com/forum/viewtopic.php?t=17726&highlight=freq
http://www.ccsinfo.com/forum/viewtopic.php?t=20039&highlight=freq
Did you read/understand/test the CCS ex_freqc.c code in the Examples Folder ?
I strongly recomend to read the microchip AN 41214.pdf found in the first link.
Humberto
