schulle Guest
place presets in internal Eeprom |
Posted: Fri Mar 17, 2006 9:23 am |
I want to place presets in the internal eeprom which I can access later on with read_eeprom(), but I found nothing if i can do this and how.
I'm using 16F684.
Does anybody know howto do this? |
rberek
Joined: 10 Jan 2005 Posts: 207 Location: Ottawa, Canada
Posted: Fri Mar 17, 2006 9:48 am |
write_eeprom(address,data) |
mpfj
MPLAB allows you to preset the EEPROM when programming devices.
Or you can preset the locations yourself on boot up by checking for a known "magic" value at a known EEPROM location. If the "magic" value exists, you know that the EEPOMR has already been preset. If no magic value is found, you can load the EEPOMR using write_eeprom().
There are several other threads covering this, so do a search for EEPROM. |
Mark
Posted: Fri Mar 17, 2006 12:15 pm |
You can also use the #ROM directive. |
schulle
Posted: Fri Mar 17, 2006 4:54 pm |
I just found out #ROM 0x2100 works fine! |
