Sampling with ADC
micknfld
Sampling with ADC
PostPosted: Thu Mar 16, 2006 1:40 pm     Reply with quote
I am having troubles sampling multiple voltages with the ADC of a 16F877. I was initially sampling within a timer interrupt but saw on this board that I could use ADC_READ_ONLY and ADC_START_ONLY to not delay within the interrupt. I can get it working when I sample only one analog port but when I try to sample two ports my values are wrong. For example, when I apply 5V to A2 and 0V to A3 then the corresponding ADC outputs are 345 and 34 respectively. They should be 1023 and 0. If I apply the same voltage to both A2 and A3 then the ADC displays the correct values. It seems as if one analog port is affecting the other. Is there a problem with not having enough delay between switching analog ports and sampling them? I even tried putting a 20us delay at the end of my timer interrupt. This improved it a little but it was still not correct. The timer interrupt is called 125 times per second. So I sample one channel 62 times per second and the other channel 63 times per second and then take the average. Here is my code:
#include<16f877.h>
#fuses HS,NOWDT,NOPROTECT
#device ADC=10
#use rs232(BAUD=9600,XMIT=PIN_C6,RCV=PIN_C7)
#opt 9
#ORG 0x1F00,0x1FFF {} //reserve top 255 bytes of memory for the bootloader
#include <lcd.c>
#define INTERRUPTS_PER_SECOND 125            // 125 interrupts per second
int32 seconds = 0;                        // A running seconds counter
long interrupt_count;                     // Number of interrupts left before a second has elapsed
long CT1_Sample = 0;                     // Save average sample
long CT2_Sample = 0;                     // Save average sample
long CT1_Sample_temp = 0;                  // Save instantaneous sample
long CT2_Sample_temp = 0;                  // Save instantaneous sample
boolean update;
void clock_isr();
void print_sample();
void reset();
// #INT_TIMER2
#INT_TIMER2
void clock_isr() {
   if (interrupt_count%2 == 0){                  // Happens 62 times per second
      CT1_Sample_temp += read_adc(ADC_READ_ONLY);      // Sample CT1
      set_adc_channel(3);                        // Change ADC channel to sample CT2
   }else{                                    // Happens 63 times per second
      CT2_Sample_temp += read_adc(ADC_READ_ONLY);      // Sample CT2
      set_adc_channel(2);                        // Change ADC channel to sample CT1
   if(--interrupt_count == 0) {                  // One second reached.
      ++seconds;
       interrupt_count = INTERRUPTS_PER_SECOND;
      CT1_Sample = (long)(CT1_Sample_temp/62);      // Calculate average
      CT2_Sample = (long)(CT2_Sample_temp/63);
      if (seconds%2 == 0){
         update=true;                        // To call print_sample()
   read_adc(ADC_START_ONLY);
// print_sample()
void print_sample(){
   printf("CT1 Sample: %lu \n\r", CT1_Sample);
   printf("CT2 Sample: %lu \n\r", CT2_Sample);
// reset()
void reset(){
   update = false;
   CT1_Sample = 0;
   CT2_Sample = 0;
   // Setup ACD Ports
   SETUP_ADC_PORTS(ALL_ANALOG);            // A0 A1 A2 A3 A5 E0 E1 E2 Ref=Vdd
   setup_adc( ADC_CLOCK_INTERNAL );
   set_adc_channel(2);
   delay_us(20);
   // Setup Timer2 to count every second
   set_timer2(0);
   setup_timer_2(T2_DIV_BY_16, 250, 10);      // setup_timer_2(mode, period, postscale)
// main()
void main(){
   reset();
   printf("\n\rPrint Analog Samples\n\r");
   while(true){
      if (update==true){
         update=false;
         print_sample();
Here is the code I used without using ADC_READ_ONLY and ADC_START_ONLY.
#include<16f877.h>
#device ADC=10
#opt 9
#include <lcd.c>
int32 CT1_Sample = 0;                     // Save instantaneous sample
int32 CT2_Sample = 0;                     // Save instantaneous sample
boolean update;
void clock_isr();
void reset();
// #INT_TIMER2
#INT_TIMER2
void clock_isr() {
      ++seconds;
      CT1_Sample = 0;
      CT2_Sample = 0;
      set_adc_channel(2);
      delay_us(20);
      CT1_Sample = read_adc();
      set_adc_channel(3);
      delay_us(20);
      CT2_Sample = read_adc();
         update=true;
// print_sample()
// reset()
void reset(){
   update = false;
   // Setup ACD Ports
   SETUP_ADC_PORTS(ALL_ANALOG);            // A0 A1 A3 Ref=Vdd
   set_timer2(0);
// main()
void main(){
   reset();
   printf("\n\rs - Print Analog Samples\n\r");
   while(true){
      if (update==true){
         update=false;
         print_sample();
This code worked but I've read on this forum that it is not good to sample the ADC from within the interrupt and I wanted to get rid of the delays within the interrupt. The CCS manual says that you should have a 10us delay after switching analog ports but I took out the delay and it still works. Any ideas?
micknfld
PostPosted: Thu Mar 16, 2006 2:17 pm     Reply with quote
It seems that it might have something to do with my math when I am trying to compute the average. I seem to get correct results when I just do this:
#INT_TIMER2
void clock_isr() {
      ++seconds;
      if (seconds%2 == 0){                        // Happens 62 times per second
         CT1_Sample = read_adc(ADC_READ_ONLY);         // Sample CT1
         set_adc_channel(7);                        // Change ADC channel to sample CT2
         update=true;
         CT2_Sample = read_adc(ADC_READ_ONLY);         // Sample CT2
But I still need to average my samples. I'll keep trying.....
micknfld
PostPosted: Thu Mar 16, 2006 2:59 pm     Reply with quote
I changed it to print just the sum of the 62/63 samples per second:
void clock_isr() {
      ++seconds;
      CT1_Sample = CT1_Sample_temp;      // Calculate average
      CT2_Sample = CT2_Sample_temp;
      set_adc_channel(3);
For A2 at 5V and A3 low I get :
CT1 Sample: 23091
CT2 Sample: 220
CT1 should be around 1023*62=63426.
For A2 at 5V and A3 at 5V I get :
CT1 Sample: 63293
CT2 Sample: 64431
Not sure whats happening here.
