Common SCL for several I2C busses
kender
PostPosted: Wed Mar 15, 2006 1:14 pm     Reply with quote
Colleagues,
Since many of you have been using I2C bus for a long time, I just wanted to run this idea by you. Is it possible to have two I2C busses that share a common SCL line? Like this:
|      |  SDA1
|   RB1|--------------------
|      |  SDA2
|   RB2|--------------------
|      |  SCL - common clock
|   RB3|--------------------
Master for 2 I2C busses
Pull-ups and slave devices not shown
Of course, PIC’s I2C hardware will not support it, but I could write custom bit-banging routines.
Nick
newguy
PostPosted: Wed Mar 15, 2006 1:51 pm     Reply with quote
I don't see an issue with it. When bus 1 is active, the devices on bus 2 shouldn't repond at all since they won't see any valid start or stop conditions.
Now that I think of it, I'm not sure how the slave devices will respond to a clock toggling but the data line staying high (I assume). You know for a fact that the slaves will ignore data that's not meant for them. If the data line on the inactive bus idles high, that equates to an address of 0xff - and you'll only have problems if one of your slaves has this address (which I doubt).
To begin, try coding things so that i2c_start() and i2c_stop() put valid start and stop conditions on both busses simultaneously. Then your i2c reads and writes can be directed to one or the other. The inactive bus will then see:
valid start - address 0xff - data 0xff - valid stop
This should pretty much guarantee that the slaves on the inactive bus won't interfere/respond/get screwed up.
If this works, then try sending valid start & stop conditions to only one bus or the other and see if things keep working properly. My first impression is that they will, but I'm not 100% sure. In this case the inactive bus will see the clock toggling but the data line will remain high all the time. I have a sneaking suspicion that the slaves may inadvertently get sent part of a start condition or part of a stop and that may cause some flaky operation when you try to address them.
Hope this makes sense.
treitmey
PostPosted: Wed Mar 15, 2006 2:24 pm     Reply with quote
May I ask why you want to do this?
kender
PostPosted: Wed Mar 15, 2006 2:34 pm     Reply with quote
Some I2C slave chips don't have address select pins, or don't have enough of them. Sometimes I run out of addresses. But if the same slave addresses are on different busses, they will not collide, as long as I'm communicating on one bus at a time. This is the reason for this proposed topolgy.
Other reasons (which are not addressed by my topology) include:
- If you have fast and slow devices, and one wants to utilize the speed of the fast devices, you should have 2 busses: fast and slow.
- If some slaves are powered by+3.3V and some by +5V, one can consider using 2 separate busses with separate SCL and SDA. The first bus would have pull-ups to +3.3V and the second one will have pull-ups to +5V.
Mark
PostPosted: Wed Mar 15, 2006 3:06 pm     Reply with quote
I would share the data line and keep the clock separate.
kender
PostPosted: Wed Mar 15, 2006 3:44 pm     Reply with quote
A year or so ago I saw an app note, which described how to share the SDA and multiplex SCL with a multiplexer chip.
jds-pic
PostPosted: Thu Mar 16, 2006 7:25 am     Reply with quote
if you can't spare the pins on the PIC to synthesize an additional SW-driven i2c port, use an external i2c switch/mulitplexer, e.g. Philips PCA9546A
http://www.standardics.philips.com/products/pca/pdf/pca9546a.pdf
this device also provides a level-translating function.
lots of variants of the above are listed here:
http://www.standardics.philips.com/products/pca/all/
jds-pic
