reading information serially
ninebarmaximus
PostPosted: Wed Mar 15, 2006 7:57 am     Reply with quote
I want to read information from a smart card
What i want to know is how would i implement a pin on the 16f74 to receive information that is being sent to it serially
I already have a circuit set up so that this pin (which ever one i choose to use) will be used for input only
I will be reading in binary from the smart card
Do i have to set up several variables to capture each binary bit, or can i just let it run and have all the binary in the one variable?
is there a way of saving the information to the internal eprom as it arrives on the pin for transmission to a computer via comm1 later?
Im sure someone here has some experience in this sort of serial communication and thanks in advance for any information that is provided, if you need to know more about what im doing or if the information i have provided is of no use or is to vague please let me know
cheers
ninebarmaximus
PostPosted: Wed Mar 15, 2006 11:03 am     Reply with quote
I was thinking of something like this please tell me if it is feasible
char reset_instring[112];//estimate that responce will be 14 bytes
void A_Reset()
output_high(pin_xx)     //RST is set to high mode
While (input(pin_xx));
        for (i=0;i<112;I++)
               reset_instring[i]=input(pin_xx);//input taken from pin chosen to be received info from sim card
the main reason i think this might be dodgy is that information is being sent on each clock pulse and this code i think will take more than one clock pulse to input each binary digit
does anyone know of a better method of doing this??
Cheers
PostPosted: Wed Mar 15, 2006 11:34 am     Reply with quote
Internal EEPROM. No way. Takes typically 4mSec to write a byte...
You say '16F74'. This doesn't have internal EEPROM.
A 112 byte array on the 16F74 won't work. It has a maximum contiguous 'block' in the RAM, of just 96 bytes.
One 'clock pulse' of what clock?.
If the clock is even close at the processor instruction rate, forget doing it in a PIC. You will need to build a hardware memory controller in discrete logic, or a FPGA, and store the data into this. The PIC will take at least half a dozen instruction times, just to read a bit, and loop. With a counter, and test, add another four or so instructions. With an array access, probably another 8 instructions. Say close to twenty instruction times at the best.
ninebarmaximus
PostPosted: Wed Mar 15, 2006 12:08 pm     Reply with quote
Fair comment i hadnt really thought about how the clock cycles were going to affect each instruction,
oh and its 112 bits of information 14 bytes that i would be expecting from the answer to reset
thanks for the info it will give me plenty to cogitate on
PostPosted: Wed Mar 15, 2006 12:50 pm     Reply with quote
I don't know the protocol used by SMART cards, but isn't it possible to use the UART or SPI module?
Isn't a SIM card used in mobile telephones a special edition of SMART cards? If yes, using the search function of this forum should give you some useful pointers.
ninebarmaximus
PostPosted: Wed Mar 15, 2006 2:50 pm     Reply with quote
Well since the first post i have realised, i really should have realised earlier, that the external clock supplying both pic and sim card is running at 4.9152MHz and at this speed the sim card will transmit/receive at 9600, so i have since set up the USART to master mode, transmit enable, synchrounous, low speed and the baud rate generator set to 9600.
and have receive pin set to serial port enable 8 bit continous receive, dont really know yet if these are the correct values yet but im gettin there, the thing i need to know now is mainly the origional question how do i set up variables to grab information that is being sent back from the sim
cheers again
ninebarmaximus
PostPosted: Wed Mar 15, 2006 2:59 pm     Reply with quote
this is the code i am using,, not finished but its a start getting a strange compiler error it says that i have an undefined identifier putchar at the point shown below, do i need an include file for that i would have thought that the compiler would know of one of the main operans such as putchar
#include "C:\finbar\Sim.h"
#include <stdio.h>
char answer;
int timeout;
char instring;
long clock_count;
long i;
long j;
void set_up_contacts()
output_low(pin_B4);    //RST is in state L
delay_us(10);
output_high(pin_B7);    //VCC is set to high
delay_us(10);
output_high(pin_B3);    //VPP is raised to idle
delay_us(10);
output_high(pin_B1);    //I/O transmit to card set to off---(receive from card enabled)---
delay_us(10);
output_low(PIN_B0);     //CLK is allowed to transmit to card
void A_Reset()
output_high(pin_B4);     //RST is set to high mode
While (input(pin_C7))
{  clock_count++;
   if ((input(pin_C7)) && clock_count >40000)
      goto start;
for (i=0;i<112;i++)
reset_instring[i]=input(pin_C7);//input taken from pin chosen to be received info from sim card
//if needed can put a delay in here to get everypulse
//need to transfer all the information in array to a series
//of byte size strings to send to PC via RS232
for (j=0;j<112;j++)
   putc(reset_instring[j]);<---HERE IS THE ERROR LINE SPECIFIED<---
void set_usart_speed()
#asm
bsf      STATUS,RP0     //memory bank 1
movlw    0x7F           // 9600
movwf    b'10110000'    //master,8bit,transmit enabled,sync,low speed
movwf    TXSTA
bcf      STATUS,RP0     //memory bank 0
movlw    b'10010000'    //serial port enable,8bit,continous receive
movwf    RCSTA
clrf     TXREG          //clear TXREG
bcf      PIR1,TXIF
#endasm
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
//at this point all the contacts for the sim card should be disabled to avoid damaging the card
#use rs232(baud=9600, parity=n, bits=8, xmit=pin_a0, rcv=pin_a1, errors)
#use fixed_io(c_outputs=PIN_C6, c_inputs=PIN_C7)
set_usart_speed();
//must turn off all contacts to the card before they can be turned on in correct order
output_low(pin_B7);    //VCC is set to high
output_low(pin_B3);    //VPP is raised to idle
output_low(pin_B1);    //I/O transmit to card set to off---(receive from card enabled)---
output_high(PIN_A0);     //CLK disabled
//this code is to see if RS232 is operating correctly
start:
answer = 'g';
timeout = 1;
   while(!kbhit()&&(++timeout<500)) //5ms apparently
      delay_cycles(1);
   if(kbhit())
   answer=getch();
   goto start;
   if (answer != 'g')   //fairly redundant since it has to have an answer to get this far
      putc(answer);
   if (answer == 'c')
      set_up_contacts();
   if (answer == 'r')
      A_Reset();
   goto start;
[/b]
PostPosted: Thu Mar 16, 2006 2:47 am     Reply with quote
Move the #use rs232 and #use fixed_io lines to the start of your program, or at least before the first use of any putc and I/O statements, and _never_ place these lines inside a function but at the global level.
Which processor are you using? I don't see a line like
#include <16F74.h>
Also the #fuses are not shown. Are these in sim.h?
You still have the 112 bytes aray, this won't fit in a PIC16F74. Also note that the putc function will transmit bytes, not bits. Make it a 14 byte array.
ninebarmaximus
PostPosted: Thu Mar 16, 2006 9:49 am     Reply with quote
In the asm code im using above i get an error when i try to switch banks!! do i just leave it as it is but remove the bank switching? does the compiler know which banks do what and do it automatically?
Also im using hte 16f74 its contained in the sim.h file
#include <16C74.h>
#device adc=8
#fuses NOWDT,RC, PUT, NOPROTECT
#use delay(clock=4915200)
PostPosted: Thu Mar 16, 2006 3:25 pm     Reply with quote
Yes.
The internal assembler, is not standard ASM. If you address a variable, and it is in a different bank, it automatically handles the switching for you. You can use the keyword "#ASM asis", and then the assembler will not bank switch for you. This is in the latter manuals (under #ASM).
