PCF8583+PIC circuit
handsprince
PCF8583+PIC circuit
PostPosted: Tue Mar 14, 2006 11:29 pm     Reply with quote
anyone can teach me how to connect pcf8583 to PIC16f877?? Thank for your kindness.
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Tue Mar 14, 2006 11:52 pm     Reply with quote
Look at the fig.22 of this datasheet http://www.semiconductors.philips.com/acrobat_download/datasheets/PCF8583_5.pdf
Your PIC will be a Master transmitter. If your PIC has the hardware I2C and you want to use it, connect the SCL line to the PIC's SCL pin and SDA line to the PIC's SDA pin. If you PIC doesn't have hardware I2C, you can use any pair of digital I/O pins for bit-banged I2C. Don't forget the pull-up resistirs. For the Vcc=+5V the pulups should be 2.2k.
Good luck
help!!!!
PostPosted: Wed Mar 15, 2006 5:03 am     Reply with quote
kender can u give me a webside that show the connection between pcf8583 and pic.... why we need pull-up resistor?? thank
PICoHolic
PostPosted: Thu Mar 16, 2006 3:11 am     Reply with quote
As a background you should get a document describing the i2c protocol (from the net) after that start reading about the i2c hardware in any PIC (that supports i2c) datasheet.
And then you'll get the answers
