How to reading data from RS232 via Hyper Terminal
Eakle
PostPosted: Mon Mar 13, 2006 8:12 am     Reply with quote
Hello everyone,
First I'm very newbies in PIC and very sorry for my bad English.
My problem is I try to connect computer using 16F877A via RS232 to Hyper Terminal (Windows XP). I can send data normally but when I want to read data from Hyper Terminal, it's struck. Please see my code.
#include <16F877.h>
#define TxD   PIN_C6
#define RxD PIN_C7
#define CLOCK_SP 20000000
#define USED_EEPROM 20
#fuses HS
#fuses NOLVP, NOWDT
#fuses NOPROTECT
#use delay (clock = CLOCK_SP)
#use rs232(baud=9600, xmit=TxD, rcv=RxD)
#byte PORTA = 0x05
#byte PORTB = 0x06
#byte PORTC = 0x07
#byte PORTD = 0x08
      char ch;
      printf("1 key input number : \n");      <= THIS CODE  OK.
      ch = getc();                                     <= STRUCK ON THIS LINE.
      printf("Input = %c \n\r",ch );             <= NOT SHOW
HyperTerminal [baud 9600/ Data bits 8/Parity N/Stop bit 1/Flow Xon-Xoff]
Please teach me how to setup Hyper terminal sending data.
Or anyone have any programs which can debug serial connection code.
Thanks.
Eakle.
asmallri
PostPosted: Mon Mar 13, 2006 8:17 am     Reply with quote
change:
#use rs232(baud=9600, xmit=TxD, rcv=RxD, Errors)
Change Hyperterm to NO FLOW CONTROL (or add your own flow control to the PIC code).
Regards, Andrew
Eakle
PostPosted: Mon Mar 13, 2006 6:58 pm     Reply with quote
Thanks very much
I'll try this code.
Regards,
Eakle
Ahmed
Re: How to reading data from RS232 via Hyper Terminal
PostPosted: Mon Mar 13, 2006 8:11 pm     Reply with quote
your code looks write and I tested it is working. adjust the hyper terminal by clicking on "Restore Defaults".
I think your problem is not in the code, so check your hardware.
I had similar problem before then i found that the problem was due to (USB to Srial) cable, was sending and not recieving.
wish u luck.
Eakle
PostPosted: Tue Mar 14, 2006 12:32 am     Reply with quote
Yeah!!! Finally I got it.......
Thanks very much to everyone.
After I changed my code as asmallri's comment, check my H/W and set Hyper terminal as Ahmed's comment, it's work.
Regards,
Eakle
PIC NEWBIES MAN....
Thanks everyone.
Circuit diagram
PostPosted: Thu Mar 16, 2006 2:29 am     Reply with quote
Can anybody help me to find a circuit diagram for PC to PIC16F877A
CCSADDiCT
PostPosted: Thu Mar 16, 2006 3:45 am     Reply with quote
dude...do some searching before u post...
http://ccsinfo.com/forum/viewtopic.php?t=25905&sid=9edce340a703d7aafca7114ba01cd7a0
