Convert from PBASIC 2.5 to CCS-C
The Puma
PostPosted: Sun Mar 12, 2006 10:17 am     Reply with quote
I need some help with converting from PBASIC
with CCS-C command (procedure) can i used to convert the SHIFTOUT command to CCS C
'                 HCMS-2900 SETUP SUBROUTINE
DSPreset:
   LOW      DSP_CS               ' Activate the Display.
   HIGH   DSP_BLANK            ' Not necessary but clear
   LOW      DSP_RESET               ' RESET.
   PAUSE   5
   HIGH   DSP_RESET            ' Normal Display is now sleeping
   ' clear all the dots
   LOW      DSP_RS               ' Select DOT register
   FOR temp=1 TO 40   ' 5 bytes/char * 8 char
      SHIFTOUT DATA_,CLK,MSBFIRST,[0\8]   ' Send All Blanks for each COL.
   NEXT
   HIGH   DSP_CS                  ' Copy data to dot latch step 1.
   LOW      CLK                  ' Copy data to dot latch step 2.
   ' next step the 2 control registers start with the first
   HIGH   DSP_RS               ' select the Control Register
   LOW      DSP_CS               ' Activate the Display again.
   SHIFTOUT DATA_,CLK,MSBFIRST,[DSP_CONTROL_0]   ' Send Data bits.
   HIGH   DSP_CS                  ' Copy data to control latch step 1.
   LOW      CLK                  ' Copy data to control latch step 2.
   ' Now the 2nd control register
   SHIFTOUT DATA_,CLK,MSBFIRST,[DSP_CONTROL_1]   ' Send Data bits.
   LOW DSP_BLANK   'Show what is in the DOT registers NOTHING!
RETURN                     ' Return to program.
The Puma
PostPosted: Sun Mar 12, 2006 12:12 pm     Reply with quote
Is this any good ???
// shift out 8-bits in data MSB first
void send_byte(int data) {
   int i;
   for(i=0;i<8;i++) {
      output_bit(HCMS2911_DIN,data & 0x80);
      output_high(HCMS2911_CLK);
      output_low(HCMS2911_CLK);
      data=data<<1;
