IDE command line compiler options
luke_robson
PostPosted: Fri Mar 10, 2006 2:18 am     Reply with quote
Can anyone tell me how can I find out what are the IDE Command Line compiler options for a specific project?
I'm asking that because I get one hex using the CCS IDE and another hex from a MPLAB project. The source files are the same.
Humberto
PostPosted: Fri Mar 10, 2006 8:08 am     Reply with quote
I'm not sure exactly what are you asking for, but you will get full info for Command
Line Compiler in the CCS C Reference Manual that you can download from CCS site.
http://www.ccsinfo.com/download.shtml#CompilerManual
If what you want is to get the compiler options from an already done project,
the answer is you can't.
Humberto
treitmey
PostPosted: Fri Mar 10, 2006 9:18 am     Reply with quote
I don't use this setup, but I think you get different HEX because MPLAB is using the MPASM assembler, and CCS uses its own assembler.
Can anyone confim this??
rberek
PostPosted: Fri Mar 10, 2006 9:39 am     Reply with quote
It is normal to get different HEX files from the same source code when you use different compilers. As well, CCS has many different optimization levels (chosen via #OPT ) that will make the HEX file different between different compiles within CCS if you are changing the #OPT value.
The difference between genius and stupidity is that genius has its limits...
luke_robson
PostPosted: Wed Mar 15, 2006 12:08 am     Reply with quote
I am sorry because I wasn't clear enough.
I didn't use different compilers. I used CCS compiler with the CCS IDE interface and I got one HEX file, and I used CCS compiler and the MPLAB interface (with the CCS plugin installed) and I got another HEX file even though I used exactly the same source files.
The differences between the two HEX files is due to the different compiler options of the CCS IDE interface on the one hand and the MPLAB default CCS plugin options on the other hand.
PostPosted: Wed Mar 15, 2006 12:22 am     Reply with quote
I don't know where to find the options that are in use by the CCS IDE
because I don't own it. But to find the ones for MPLAB, go to the
Project menu and click on Build Options. For the PCM compiler
with a 16F877, these are the settings:
+DF +LS +T -A +M -Z +Y=9 +EA -EW
You could change the MPLAB settings a little bit, re-compile, and then
do a file compare with the HEX file from the CCS IDE. You would
probably quickly find out what option is causing the differences.
