CCS with Proteus VSM
alzomor
PostPosted: Thu Mar 09, 2006 10:29 pm     Reply with quote
Hi
I am using ccs for compiling my code.
and when trying to debug it on proteus.
I just only could navigate the assembly but can't navigate "step over , step into , set break points" with the C source code.
How to use CCS with Proteus VSM in order to be able to dbug at the C source code level
Salam
Hossam Alzomor
www.i-g.org
Salam
Hossam Alzomor
www.i-g.org
rberek
PostPosted: Thu Mar 09, 2006 10:50 pm     Reply with quote
Proteus VSM is not 100% compatible with the CCS COFF format, so you cannot do source code debugging. See the Labcenter page for details.
The difference between genius and stupidity is that genius has its limits...
alzomor
PostPosted: Thu Mar 09, 2006 11:53 pm     Reply with quote
Hi
Thanks for your support.
but how to do source code debugging for code generated by CCS
Salam
Hossam Alzomor
www.i-g.org
rberek
PostPosted: Fri Mar 10, 2006 6:07 am     Reply with quote
If you're using Proteus, you can't.
MPLAB does provide that ability though, if I remember correctly. I use Proteus myself, and don't bother with source code debugging. I just step through program memory. Pretty primitive, but it works for me...
alzomor
PostPosted: Fri Mar 10, 2006 10:04 pm     Reply with quote
Thanks rberek
Salam
Hossam Alzomor
www.i-g.org
PICoHolic
PostPosted: Mon Mar 13, 2006 3:26 am     Reply with quote
Which version of PROTEUS are you using?
PostPosted: Mon Mar 13, 2006 7:39 am     Reply with quote
Hi
Proteus 6.7 SP3
Salam
Hossam Alzomor
www.i-g.org
PICoHolic
PostPosted: Tue Mar 14, 2006 5:27 am     Reply with quote
Ok
Try to put the COF file instead of the HEX file
ex: Prog.hex -> Prog.cof
