Debounce routine -
alm1006
Debounce routine -
PostPosted: Tue Mar 07, 2006 11:52 am     Reply with quote
I would like to know if someone has a routine capable of debouncing any switch.
I've enclosed my jungle version of a debounce routine that's clearly not working. The routine && a 1 with FF then shifts << debounce until it equals 0. Your thoughts would be greatly appreciated.
Regards,
Albert
void TIMER2_isr(void)
cnt++; // cnt every 10ms
if (!input(pin_a4))
if (test_a4 == 0) //initialized in main
set_a4 = 1; // set_bita4 = input(pin_a4)
debounce = (set_a4 && 0xFF); // AND input(pin_a4) && 0x01
test_a4 = 1;
if (!input(pin_a4))
if (test_a4 == 1)
if (debounce >= 0x01)
1<<debounce;
output_high(pin_b2); // test bit
delay_cycles(2);
output_low(pin_b2);
a4_debounced = 1;
test_a4 = 0;
PostPosted: Tue Mar 07, 2006 12:38 pm     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?t=19874
http://www.ccsinfo.com/forum/viewtopic.php?t=23837
http://www.ccsinfo.com/forum/viewtopic.php?t=17189
Also use the forum's search engine to search for: debounce
John P
PostPosted: Thu Mar 09, 2006 1:08 am     Reply with quote
One method of switch debouncing simply involves reading the switch at a slow enough rate that any bouncing will be over and done with between tests. If you happen to check the switch during bouncing, it either will or won't be found in the new state, but this doesn't matter: if you catch it in the new state, it'll be steady by the time it's next checked and you see the new state a second time. The same is true if you fail to catch it; it'll be steady in the new state by the time the next check is done, so the only effect is to delay recognition of the new state by one cycle. There are times where you may need to have an exact timestamp for when the first transition in the switch state occurred, but if it's just a question of reading a pushbutton operated by a human, there's no need to work hard to get the data. If timing is crucial, use an optical or magnetic switch instead!
