RE: Simple LCD setup
Chorus
PostPosted: Wed Mar 08, 2006 4:36 am     Reply with quote
I'm trying to setup a very simple program to setup an lcd with an 8-bit interface and then display a single char on the screen to check it is working. Is there anything obviously wrong with my code?
#include "C:\Program Files\PICC\work\TQFPtest3.h"
#define LCD_RS PIN_E5
#define LCD_RW PIN_E6
#define LCD_E PIN_E7
#define RS_HIGH 1
#define RS_LOW 0
// Note: 8-bit LCD data bus connected to port D
void LCDputC(int8 data, int1 RS)
if(RS == RS_HIGH)
output_high(LCD_RS);
output_low(LCD_RS);
printf("data: %x\n", data);
delay_ms(1);
output_high(LCD_E);
delay_ms(1);
output_d(data);
delay_ms(1);
output_low(LCD_E);
delay_ms(1);
void LCDinit()
LCDputC(0x3f, RS_LOW);
LCDputC(0x0f, RS_LOW);
LCDputC(0x01, RS_LOW);
delay_ms(2);
LCDputC(0x02, RS_LOW);
int i;
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_4(T4_DISABLED,0,1);
setup_vref(FALSE);
setup_oscillator(False);
delay_ms(1000); // LCD power up delay
set_tris_d(0x00); // Both ports are set as outputs
set_tris_e(0x00);
output_low(LCD_RW); // Always in write mode
LCDinit(); // Init LCD function
LCDputC(0x31, RS_HIGH);
P.S: I know the PIC is working correctly as I have tested it by writing data to the serial port. Also I have checked the connections between the PIC ports and the LCD are correct.
PostPosted: Wed Mar 08, 2006 5:08 am     Reply with quote
There is LCD code supplied with the compiler, and versions with more flexible I/O, on the code forum. Why not look at these?...
Now that having been said, the initialisation sequence is not complete.
The normal sequence required, is:
delay 15 mSec (you have this)
Send 'function set'
delay 4.1mSec or more
Send 'function set' again.
wait 100uSec or more
Send 'function set' yet again.
Now send configuration
Display 'off'
Display 'on'
send 'entry mode set'
You are only sending about half of the sequence needed to ensure a good initilialisation. If you look at the supplied LCD.C code, you will see, that it sends 'function set' three times, with 5mSec between each, and only then sends the initialisation string.
You may need to adjust the LCD bias voltage to actually 'see' anything on the screen.
Chorus
RE: Incorrect init
PostPosted: Wed Mar 08, 2006 5:29 am     Reply with quote
Are you I need to send the function set command (0x3f) three times? My data sheet seems to show that I only need to send 4 different bytes with delays to setup LCD
Here is a link to the datasheet:-
http://digital-io.com/specification/Char/AA16206.pdf
PostPosted: Wed Mar 08, 2006 5:36 am     Reply with quote
The 'quad send', is the default for emulations of the Hitachi display controller, _to ensure initialisation, whatever mode the unit is in_. The problem is that the simpler sequence, assumes the unit has woken up cleanly (with the chip deselected), and this is not guaranteed. Most manufacturers show both sequences.
Even looking at the default from your data sheet, you are not meeting the timing delays they specify between the commands. These are _vital_...
