Manchester encode/decode
cosine
PostPosted: Tue Mar 07, 2006 5:33 pm     Reply with quote
I intend using the PIC16F684 and an AM transmitter board, the AM-RT4 433MHz, i would like to use Manchester coding to transmit the data, can anyone direct me to a function that will do this in "C", I am using the RC2 pin.
i also need a function to receive Manchester coding for a simular PIC, using the CCP1 capture/compare pin.
I use the CCS PCWH Compiler, and would prefer all code in "C"
any help would be appreciated
thanks
Cosine
PostPosted: Wed Mar 08, 2006 2:26 pm     Reply with quote
Use the forum search engine and search for Manchester.
There are many posts on it.
http://www.ccsinfo.com/forum/search.php
