Adding 2 16 bit numbers together
uhoh-robbo
PostPosted: Mon Mar 06, 2006 7:03 am     Reply with quote
Hey,
I'm trying to copy one int16 number to another int16 number. But they are only copying 8 bits of the 16. Any ideas?
Days[Day+1].Sensor[Node].On1 = Days[Day].Sensor[Node].On1;
the numbers are defined here:
struct SensorInfo
   unsigned char Temp;
   unsigned int16 On1;
   unsigned int16 Off1;
   unsigned int16 On2;
   unsigned int16 Off2;
   unsigned int16 On3;
   unsigned int16 Off3;
Cheers
uhoh-robbo
PostPosted: Mon Mar 06, 2006 7:05 am     Reply with quote
I know I'm accessing these numbers correctly. Just incase you were wonding I missed this bit of code out before.
struct Week
   struct SensorInfo Sensor[MAX_NUMBER_OF_SENSORS];
} Days[7];
mpfj
PostPosted: Mon Mar 06, 2006 7:30 am     Reply with quote
Could you post the listing file so we can see what is apparently going wrong ?
I've compiled some test code and it looks like it should work !!
uhoh-robbo
PostPosted: Mon Mar 06, 2006 7:39 am     Reply with quote
Yes your completely right. Its does work. the problem was in a different place.
Sorry to waste your time.
Thanks anyway
