Store ADC read value in a file???
sonicdeejay
PostPosted: Fri Mar 03, 2006 4:34 am     Reply with quote
Can I do that??
like using fprintf:"??
sonic
Smile
rberek
PostPosted: Fri Mar 03, 2006 6:18 am     Reply with quote
What do you mean? Which file system and where?
The difference between genius and stupidity is that genius has its limits...
sonicdeejay
PostPosted: Fri Mar 03, 2006 7:23 am     Reply with quote
for example...
In my Hyperterminal....
Input value is :188.9999
Input value is :190.9999
Input value is :192.9999
Input value is :182.9999
Input value is :187.9999
Input value is :193.9999
These are the input from ADC...
can I also store it in a file??
like c:\\temp\\adc.txt ??
Smile
rberek
PostPosted: Fri Mar 03, 2006 7:33 am     Reply with quote
Select "Transfer", then "Capture Text"
PostPosted: Fri Mar 03, 2006 7:37 am     Reply with quote
Well, Hyperterminal itself, has the ability to save all the incoming text to a text file. This would store what you see. Beyond this, more programming becomes necessary. If you send the data in CDF format (numbers seperated by commas), then Excel for example, can read such numbers and save them. Anything beyond this, then you would neen to write a program in your language of choice, to read the incoming serial, parse the numbers from this, and write them to a file.
SherpaDoug
PostPosted: Fri Mar 03, 2006 8:03 am     Reply with quote
Bytes is bytes. The PIC doesn't care where they come from, where they go to, or what they mean.
BTW you seem to be displaying the A/D output as a float with a rounding problem. The A/D inherently produces an integer (or long) result. There is no need to invoke the terrible overhead of floating point numbers just to print the A/D counts.
sonicdeejay
PostPosted: Fri Mar 03, 2006 10:20 pm     Reply with quote
This will be good enough...
Thx guys....
I will change input into "long" as my ADC is 10bit.......
