ex_usb_serial example help!!!!
martinisonline
PostPosted: Thu Mar 02, 2006 12:24 pm     Reply with quote
I try to build the ex_usb_serial example but it not works at all...
Lets say:
COM1: virtual com port created by the drivers (USB)
COM2: physical com port
In the COM1 --> COM2 direction everything works great
at COM2 --> COM1 direction nothing happens...
someone had the same problem???
Solutions??
Tanks in advance...
palermo
PostPosted: Sat Jul 01, 2006 5:04 pm     Reply with quote
I had the same problem, i just changed
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7)
to
#use rs232(baud=19200, xmit=PIN_C7, rcv=PIN_C6)
And now it worked.
Does anyone no the reason?
Thanks,
Bruno
PostPosted: Sat Jul 01, 2006 10:55 pm     Reply with quote
What you've done by switching the pins is to make a software UART.
A software UART can't lock up if the receiver is overrun, but the
hardware UART can.
You can test if this is the problem by putting the pins back to the
hardware UART configuration, and then adding the ERRORS parameter
to the #use rs232() statement. This will clear any overrun errors
that occur, and prevent the hardware UART from locking up.
Example:
use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
Make sure you do it exactly as shown above, with C6 for xmit and
C7 for rcv.
I don't know if this will fix the problem, but it might.
