reset_cpu() in int_rda service routine
PostPosted: Wed Mar 01, 2006 4:14 pm     Reply with quote
I thought PIC16F628A has a MCLR instruction set . . . well, it does not, but can I call reset_cpu() in RDA servicie routine?
I know stack will be left intact and possibly a harzard, but as PCM Programmer pointed in various thread, the stack is circular, so no problem . . . but are there any other issues?
Thanks in advance.
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
Re: reset_cpu() in int_rda service routine
PostPosted: Wed Mar 01, 2006 4:29 pm     Reply with quote
I'm not a big fan of microcontroller suicides, so I'm just guessing and I have never tried this myself. You could set up and strobe a watchdog timer (WDT, if your PIC has one). In the ISR you would make a long delay without strobing the WDT. WDT would reset the PIC.
PostPosted: Wed Mar 01, 2006 4:33 pm     Reply with quote
I am wondering if you really have to structure your program in this way ?
Why do you believe that you have to re-start program execution from
the reset vector (address 0x0000) if you receive a 0xFF byte ?
Why not just instead, perhaps go to the start of a while() loop ?
Humberto
PostPosted: Wed Mar 01, 2006 4:36 pm     Reply with quote
I would like to know the reason to do that.
I am convinced that it must have several elegant and much safe solutions.
Humberto
asmallri
PostPosted: Wed Mar 01, 2006 5:33 pm     Reply with quote
I have done this previously. I did have one verison of the PCH compiler that had a bug (not sure of the versions 3.229?) that required two reset_cpu() instructions one after the other to work. My code was inside a case statement and the time and the compiler incorrectly branched past the first instruction.
Regards, Andrew
PostPosted: Wed Mar 01, 2006 8:02 pm     Reply with quote
Kender, that is so funny.
Well, WDT works fine but a long delay? in milliseconds? No, I'd rather commit suicide :-)
PostPosted: Wed Mar 01, 2006 8:06 pm     Reply with quote
PCM programmer, well, I want my core code to execute without any interrupts when delay_xx() is called but want to break that tight loop, so a reset_cpu() or MCLR would be fine.
As you said, maybe I should invest some time to do my own delay routines, I did it using another compiler that does not have a lot of builtin functions but failed at accuracy. So I bought this compiler . . .
PostPosted: Wed Mar 01, 2006 10:25 pm     Reply with quote
Humberto, the reason is, I am too lazy to figure out my own PRECISE delay function.
asmallri, thanx.
