Strange problem with printf()
JPH
PostPosted: Tue Feb 28, 2006 2:40 pm     Reply with quote
Hey
I have PCH 3.242 compiler and PIC18F6722@32MHz.I have strange problem with printf() when I read data from the Sensirion SHT15 sensor. It works's right when I have uncommented one of the printf() lines in the end of the CASE 3. But when all printf() lines are commented and I try to read temp and humi inside the program, values are off the scale. When I put the program to print out temp or humi, then the function works like it should be I can read right values to other function.
So question is where should I start to look the problem?
execute(int8 number)
   switch(number)
      case 0:
         sht1x_connection_reset();
         sht1x_command_mode(MEASURE_TEMP);
         set_timer0(58660);                 //220ms
         state++;
      case 1:
         lValue_temp = sht1x_read_data();
         fTemp_true = (D1+(D2*lValue_temp));
         set_timer0(65224);               //10ms
         state++;
      case 2:
         sht1x_command_mode(MEASURE_HUMI);
         set_timer0(63503);                 //65ms
         state++;
      case 3:
         clear_interrupt(int_timer0);
         disable_interrupts(int_timer0);
         lValue_rh = sht1x_read_data();
         fRh_lin = (C1+(C2*lValue_rh)+(C3*lValue_rh*lValue_rh));
         fRh_true = (((fTemp_true-25)*(T1+(T2*lValue_rh)))+fRh_lin);
         fDew_point = sht1x_calc_dewpoint(fRh_true,fTemp_true);
         //printf("\nRelative Humidity: %3.4f%%",fRh_true);
         //printf("\nDew Point: %3.4fC",fDew_point);
         printf("\nTemperature: %3.4fC",fTemp_true);
      default:
void read_temp_humi(void)
   set_timer0(65000);
   state=0;
#INT_TIMER0
int_timer0_isr()
   execute(state);
main()
SETUP_TIMER_0(RTCC_INTERNAL|RTCC_DIV_256);
   if(!input(PIN_F1))
      read_temp_humi();
Cheers
Jussi
PostPosted: Tue Feb 28, 2006 3:21 pm     Reply with quote
It takes time to send characters with the UART. It also takes time
for the floating point printf routines to execute. At 9600 baud, it takes
about 1 ms to transmit a character.
So I would guess that just one of your printf statements is at least
the equivalent of this statement:
delay_ms(25);
That may give you a clue regarding the source of the problem.
JPH
PostPosted: Wed Mar 01, 2006 2:02 pm     Reply with quote
Thanks for the fast reply. I debugged and tested function with different interrupt times and I still didn't get it work without using at least one printf(). How should I fix the problem?
   switch(number)
      case 0:
         state++;
      case 1:
         state++;
      case 2:
         set_timer0(20000);                 //1.4s
         state++;
      case 3:
         state++;
         //printf("\nTemperature: %3.4fC",fTemp_true);
      case 4:
      default:
rnielsen
PostPosted: Wed Mar 01, 2006 3:31 pm     Reply with quote
Your problem might not be with the printf() command. I've worked with this sensor quite a bit and you need to allow the sensor to do it's thing once you give it a read() command. The sensor is not quite I2C compatible so you need to bit_bang communications to it.
Once you have sent a read() command to the sensor it will hold the SDA line High until it's finished it's measurement. Monitoring this line will allow you to know when to clock the result out of it. You can put a specified delay time if you want but, to reduce down time, simply monitor when the SDA line goes low to clock the data out.
Here's a small section of code that I have used that works quite well. The SDA line is assigned to the variable XSDA. Send_sense() and read_sense() are simply bit_bang routines. Calc_rh() and calc_temp() are routines to convert the values that are read to displayable values.
if(sensor)// time to read the sensor
  switch(status)
    CASE 1:
      if(send_sense(0x03))// send command to read the Temperature and test if it ACK'd
        status = 0;// if this is entered, the sensor did NOT ACK and we stop trying to
        sensor = 0;// talk to the sensor until the next time we want to read it
        status = 2;// if the sensor ACK'd, increment the status var
    CASE 2:
      if(!input(XSDA))// we need to wait until the sensor is finished
      {                // making it's measurement before we try to get
        stemp = read_sense(); // the data from it
        status = 3;
    CASE 3:
      if(!send_sense(0x05))// this is the read command for the RH
        status = 4;
    CASE 4:
      if(!input(XSDA))// we need to wait for the same thing as the temp
        shumid = read_sense();
        status = 5;
    CASE 5:
      if((!stemp && !shumid) || (stemp > 0x3FFF || shumid > 0xFFF))
      {                       // if the sensor has
        if(pwr++ > 10) // wigged out, cycle the power to it
          puked = 1;
        cycle_power();
        TEMP = calc_temp(stemp);
        HUMI = calc_rh(shumid);
        pwr = 0;
      status = 6;
    CASE 6:
      if(!send_sense(0x07));// this sends the command to address the Sesor's
      {                            // Status Register
        status = 7;
    CASE 7:
      if(!input(XSDA))// we need to wait until the sensor is ready to
      {                 // send the data
        r_stat = read_status();
        if((r_stat & 0x40) == 0x40)// mask out unwanted bits
          if(eol_status++ > 9)// test the End of Life bit from the sensor and
          {                    // if it is set for 9 straight tests...
            eol_done = 1; // set the End of Life status bit
          eol_status = 0;
          eol_done = 0;
        status = 0;// reset these flags for the next use
        sensor = 0;
    default:
  }// end of switch()
}// end of if(sensor)
This code is placed inside of main() and a timer sets a flag 'sensor' whenever a measurement needs to be made. Since it's inside of main() each Case is tested every scan and there is very little down time waiting for any delay.
Clear as mud? Twisted Evil
Ronald
