is my RS485 connection wrong?
kitty
PostPosted: Sat Feb 25, 2006 7:52 pm     Reply with quote
I am using MPLAP IDE v6.60, 18F458, and try to using testing code to try rs485 connection between 2 PIC that is master and slave with MAX485.
my connection pin as below:-
PIN_C7 to RO
PIN_C6 to DI
PIN_B4 to DE
PIN_B5 to RE
ground to pin 5
+5 to pin Vcc
pin A of max485(master) to pin A of max485(slave)
pin B of max485(master) to pin B of max485(slave)
after compile and write to PICs, nothing show at LCD.
Why?
//master
#include<18f458.h>
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT
#use delay(clock = 20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, enable=PIN_B4, stream=RS485)
#define RS485_ID           0x10        // The device's RS485 master address
#define RS485_USE_EXT_INT    TRUE        // Select asynchronous serial interrupt
#include<RS485.c>
#include <lcd.c>
int buffer[40];
int next_in  = 0;
int next_out = 0;
#INT_RDA
void serial_isr()
   int t;
   buffer[next_in] = fgetc(RS485);
   t = next_in;
   next_in = (next_in+1) % sizeof(buffer);
   if(next_in == next_out)
      next_in=t;        // Buffer full !!
   int j;
   int data_received[32];
   lcd_init();
//   lcd_putc("\fSystem ready.\n");
   enable_interrupts(INT_RDA);
   rs485_init();
      rs485_wait_for_bus(FALSE);
                   //send address=0x11, length = 1, msg=3
      if(rs485_send_message(0x11, 1, 3))
         printf("\ftest 1");
      delay_ms(5);
      if(rs485_get_message(data_received, FALSE))
         for(j=0;  j<3; ++j)
                  data_received[j] = buffer[j];
               if(data_received[2]==6)
            //if slave receives the number 3 successfully
         {                    //slave will send back number 6
            printf(lcd_putc, "\ftest");
//slave
#include<18f458.h>
#define RS485_ID  0x11                 // The device's RS485 slave address or ID
#include<RS485.c>
#include <lcd.c>
int buffer[40];
int next_in  = 0;
int next_out = 0;
#INT_RDA
void serial_isr()
   int t;
   t = next_in;
   int j;
   lcd_init();
   rs485_init();
lcd_putc("\fSstem ready.\n");
      if(rs485_get_message(data_received, TRUE))
         for(j=0;  j<3; ++j)
         if(data_received[0] == 0x11)
            printf("\ftest");
            //after receive successfully, respond to master by sending number 6
            if(rs485_send_message(0x10, 1, 6))
               printf("\ftest");
Humberto
PostPosted: Sat Feb 25, 2006 10:19 pm     Reply with quote
This directive should be used if you want to use the EXTERNAL INTERRUPT PIN as software UART receiver.
This directive also override the pins selected in the previous #use rs232(.....) directive.
But your intention is to use the built-in hardware UART because you selected the dedicated UART pins:(in bold)
Hence you need to use this directive, (or not use at all) because you DO NOT want to use the
EXTERNAL INTERRUPT PIN as UART receiver.
#define RS485_USE_EXT_INT FALSE // Select asynchronous serial
PIN_C7 to RO
PIN_C6 to DI
PIN_B4 to DE
PIN_B5 to RE
ground to pin 5
+5 to pin Vcc
This is OK but DE and RE must be tied together or keep RE low.
Humberto
kitty
rs485
PostPosted: Sun Feb 26, 2006 9:54 pm     Reply with quote
Thanks, humberto.
I change my code as you told :
//master
#include<18f458.h>
#include<RS485.c>
#include <lcd.c>
int buffer[40];
int next_in  = 0;
int next_out = 0;
//#INT_RDA
void serial_isr()
   int t;
   t = next_in;
   int j;
   lcd_init();
 //  enable_interrupts(INT_RDA);
 //  enable_interrupts(GLOBAL);
   rs485_init();
          lcd_putc("\fsend 1");
      delay_ms(5);
//slave
#include<18f458.h>
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, enable=PIN_B4, stream=RS485)
#define RS485_USE_EXT_INT FALSE        // Select asynchronous serial interrupt
#include<RS485.c>
#include <lcd.c>
int buffer[40];
int next_in  = 0;
int next_out = 0;
//#INT_RDA
void serial_isr()
   int t;
   t = next_in;
   int j;
   lcd_init();
   rs485_init();
        data_received[0] = buffer[0];
      data_received[1] = buffer[1];
      data_received[2] = buffer[2];
      data_received[3] = buffer[3];
printf(lcd_putc,"\f%d %d %d %d",data_received[0],data_received[1],data_received[2],data_received[3]);
When those PICs run, master keep on sending to slave. But I am trying to retrive data at slave PIC using data_receive[0] to [3], I think this is not the right way because non of them show number 3 that send from master.
Very sorry, I try to read all post from search rs485 but I can solve it.
Please help & thanks.
Humberto
PostPosted: Mon Feb 27, 2006 6:20 am     Reply with quote
The system is behaving according to the code that has written.
1) I don't see any code in your Slave that will send back data to the Master.
2) I don't see any code in your Master to show the retrieved string, something like this:
Does your Slave is receiving the data packet ?
Humberto
kitty
PostPosted: Mon Feb 27, 2006 11:02 pm     Reply with quote
Hi, thank for reply.
In fact my master can send data because I connected one led at TX line and It blink when sending data.
I only sending data number 0 to 15 from master to slave.
//master pic
      if(rs485_send_message(0x11, 20, j))
          printf(lcd_putc,"\fsend %d",j);
      if(j<15)j++;
      else j=0;
but I do not know the right way to reveice data at slave site. I try the code as below
//slave pic
       if(rs485_get_message(data_received,FALSE)){
      for(j=0;j<data_received[1];++j)
         fputc(data_received[j+2],RS485);
         l=data_received;
   printf(lcd_putc,"\f%d %d %d ",data_received[0],
data_received[1],data_received[2]);
lcd at slave pin doesnt get the right massage from master.
I do not know what to do now?
