what's wrong with this simple A/D code?
eliberg
PostPosted: Thu Feb 16, 2006 7:22 am     Reply with quote
Hi to everyone,
I'm trying to simply convert an analog input using the ad module of the PIC18F4431.
The analog input is on the AN0 pin, the range of the voltage is 0-5V (Vdd-Vss).
The problem is that whatever I put on the AN0 pin (0V, 1V, 3V...5V) I always read adc3=1023.
Trying to visualize adresh and adresl I obtained that adresh=3 and adresl=255.
I'v also tried setting manually each of the AD registers, but it was the same. Always 1023.
What's wrong?
The code is the following:
#include <18F4431.h>
#device adc=10
#fuses HS, NOPROTECT, NOBROWNOUT, NOWDT, NOLVP, PUT, NOSTVREN, NOFCMEN, NOIESO, MCLR
#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,parity=N,bits=8)
#define led_status PIN_D7
{ unsigned int16 adc3=0;
output_bit(led_status,1);
delay_ms(2000);
output_bit(led_status,0);
printf("\n\r adc alive");
setup_adc_ports(sAN0|VSS_VDD);
while (1)
set_adc_channel(0);
delay_us(20);
adc3=read_adc( );
printf("\n\r adc=%lu",adc3);
Thank you.
Eli
dr
ADC problem
PostPosted: Thu Feb 16, 2006 7:57 am     Reply with quote
I think your syntax is wrong here. In my usage, setup_adc_ports( ALL_ANALOG) always works. I don't know how that would pan out with the
18F4431 though.
rnielsen
PostPosted: Thu Feb 16, 2006 9:38 am     Reply with quote
#device adc=10
Change this to:
#device adc=16
Plus, your result will be a 10 bit value and uses two full Bytes. This leaves six bits unused. The register bit ADFM controls which 'side' of these two bytes will be stuffed with zero's. ACCON2 contains bit ADFM. ADFM defaults to a value of '0'. This will Left justify the result, meaning the lower six bits will be zero's. Setting ADFM to a '1' will Right justify the result and, maybe, give you the result you are looking for.
Ronald
eliberg
PostPosted: Thu Feb 16, 2006 11:05 am     Reply with quote
Thanks for the replays.
First of all I need just one AN pin, so I cannot use ALL_ANALOG, also because the other possible AN pins are used as digital I/O, in my project.
In the 18f4431.h "setup_adc_ports(sAN0|VSS_VDD)" is the right syntax to set AN0 as analog, from 0 to 5V.
Second, I'm not sure I can use #device adc=16, because the AD module is a 10bit AD converter, in the 18F4431, so I can set adc=8 or adc=10.
Anyway I will try, thanks for the idea.
In the meanwhile I think I solved the problem by myself. Smile Inserting "set_tris_a(0b00011001)" now the adc works. The only strange thing is that the digital value becomes 255 when the input voltage is 4V, not 5V.
Any idea for this new problem?
Thank you very much!
Eli
Humberto
PostPosted: Thu Feb 16, 2006 11:19 am     Reply with quote
Is right.
If you use #device adc=10 the output range is 0 - 03FF
If you use #device adc=16 the output range is 0 - FFC0
Nop. It would be:
     255 = 1.25V
     512 = 2.50V
    1024 = 5.00V
Unles you are looking only the less significant register of 0x03FF
Humberto
eliberg
PostPosted: Mon Feb 20, 2006 7:34 am     Reply with quote
Ok, with #device=10 I obtain 1023 at 4V, instead of 5V.
The same problem with #device=8 (255 at 4V).
I don't know where is the problem!
eli
rberek
PostPosted: Mon Feb 20, 2006 8:16 am     Reply with quote
Do you know for a fact that your supply rail is 5V?
If it has drooped to 4V, then you will get the full reading at the lower voltage.
The difference between genius and stupidity is that genius has its limits...
eliberg
PostPosted: Fri Feb 24, 2006 6:56 am     Reply with quote
Yes, I'm sure my voltage is 5V, but if I set my Vdd, for example, to 5.5V, the ADC gets 1023 to 4.5V.
Do you think it cuold be a "broken" PIC?
eli
PostPosted: Fri Feb 24, 2006 7:41 am     Reply with quote
Double check that the supply is actually 'right' at pin11. This is the pin used for the analog reference.
Yes, it could be a faulty PIC, possibly in the MOSFET used to connect the reference to the ADC.
