help! spi ADC using PIC
BeaTk
PostPosted: Thu Feb 23, 2006 7:20 am     Reply with quote
I try to connect MCP3001 connect with PIC16f88 but I can't write the program to get the value from the ADC. Could anyone help me with the coding
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOCPD,NOWRT
int x = 0;
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
spi_write(0x3c);
if(spi_data_is_in())
x=spi_read();
delay_ms(11);
delay_ms(11);
I try to use this code but I dont know how to get value from the ADC
iso9001
PostPosted: Thu Feb 23, 2006 12:11 pm     Reply with quote
You didnt use a CS pin.
Your chip isn't listening because its not selected..... CHIP SELECTED...
Tie an output to the CS pin, output_low before a command and output_high after.
rberek
PostPosted: Thu Feb 23, 2006 12:23 pm     Reply with quote
Plus, the code you chose has some syntax problems. Read further in the thread you got it from to see some of the advice given to its author
The difference between genius and stupidity is that genius has its limits...
iso9001
PostPosted: Thu Feb 23, 2006 1:39 pm     Reply with quote
Also, you may have to look into MODE 00 or 11 for SPI... there are posts about this, one from DougH I think.
Oh, your pic may have to supply the clock to the MCP... so try a
x=spi_read(0);
That will send a 0 which the ADC will probably ignore, but it will make the clock line pulse giving the ADC an oppertunity to send its data to you. Kinda.
And... You never check 'x'
PostPosted: Thu Feb 23, 2006 2:56 pm     Reply with quote
That code is junk code. It's not a driver. Don't use it.
