John Ilicitean
| SPI comunication problem |
Posted: Wed Feb 22, 2006 4:42 am |
Hello to EveryONE!
I connect a PIC16f877 to AD with the bus SPI. This is my first code of SPI. For the line DOUT I want to send the data "3c". The AD have a CS active a "0".
I connect: the DIN of PIC with DIN of AD
the DOUT of PIC with DOUT of AD
the SCLK of PIC with SCLK of AD
This is my code:
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOCPD,NOWRT
int x = 0;
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
spi_write(0x3c);
if(spi_data_is_in())
x=spi_read();
delay_ms(11);
delay_ms(11);
The SCLK not send the pulses of CLK and the DIN not send the data "0x3c".
The way to work in SPI bus is correct??
I have correctly connected the lines of the SPI bus???
It is necessary to put R pull-up??? |
Posted: Wed Feb 22, 2006 5:09 am |
General comment. Normally Data out on one device, goes to Data in on the other.
Now, the clock line should run, even with this wrong. Are you sure you would see the clock signal. It'll be at 1.25MHz with the timings you have selected. Given there are only eight clock pulses, this wll be difficult to see, unless you have a storage scope.
Second comment, you don't say what DAC is involved, but normally, you have to send the command bytes, and then _clock back_ the reply. The SPI_read, will return the byte clocked back, while the command was sent. Normally this is a dummy byte, and you then then have to clock a second byte out, to get the reply. SPI_DATA_IS_IN, will always be true after sending the first byte, since the master has developed the clock for a byte.
So:
Check the data connections. The data sheet should say which is the input, and the output pin. You want the input connected to the PIC's 'out', and vice-versa.
Then try:
spi_write(0x3c);
//Check the data sheet - does the chip need a delay, before
//data can be read?.
x=spi_read(0);
//Adding the '0' here, makes the master clock out a dummy byte
//to get the returned data.
delay_ms(11);
I'd suggest posting the ADC part number, since we can then tell you whether this is right. At present it is a 'guess', based on some SPI ADC's I have used.
John Ilicitean
Posted: Wed Feb 22, 2006 6:08 am |
Hi!!
The AD is the AD7789. In the datasheet show in the "Continuous Read Mode" if I send the "0x3c" for DIN , in DOUT is put the data register.
I have a digital storage oscilloscope to be able to see the clock pulses.
In the line SCLK not appears this pulses(I am afraid that here is the problem).
I have put by defect "SPI_CLK_DIV_4" but I don't know the differences between putting "SPI_CLK_DIV_16" or "SPI_CLK_DIV_64" |
Posted: Wed Feb 22, 2006 9:32 am |
| Quote: | | The SCLK not send the pulses of CLK |
| Quote: | I connect: the DIN of PIC with DIN of AD
the DOUT of PIC with DOUT of AD |
| Quote: | {
while(1); {
spi_write(0x3c);
x=spi_read();
delay_ms(11);
delay_ms(11);
What happened to your promise to use an A/D chip that
already has a known-good, working driver ?
You are going on the same path as the previous time.
You need to take a class in hardware and in the C language.
If you did this, you would not make the mistakes shown above. |
John Ilicitean
Posted: Wed Feb 22, 2006 9:51 am |
I went to buy the converter that you said to me, and they said that I send
to me in a month.I cannot wait for as much time. For this reason I buy the AD7789.
Single I need aid, like everybody. |
Posted: Wed Feb 22, 2006 10:09 am |
| John Ilicitean wrote: | Hi!!
No.
You have to send 3C, wait for the conversion to complete, and _then_ clock back _three_ bytes of data.
Look at page 16 of the data sheet.
You will need to be a bit more ingenious than your current code to do this. You will need a pull up resistor on the Dout pin of the chip (the chip uses this pin to signal that a conversion has completed, as well as to transfer the data.
You then need something like:
int32 value;
SPI_WRITE(0x3C);
while(input_bit(PIN_C4)); //Wait for the data to be ready
value=make32(read_spi(0),read_spi(0),read_spi(0));
You also need to set the CKP bit in the SPI configuration, so that the SPI idles high, or the chip will continuously reset. |
John Ilicitean
Posted: Fri Feb 24, 2006 6:13 am |
Hello!!!
Ttelmah thank's for to help me .I proved your code. In the SCLK line I see the pulses of CLK ,four trains of pulses of 8 bits,like in the figure 16.
In the first train of pulses I see in the DIN line the data of "3c",until here all correct one.
According with datasheet , now the DOUT must to appear the data register but in this line appears, in the second trains of pulses( in the third bit of CLK) a pulses on DOUT and the rest of time are a low level.In this line are a Pull-up Resistor of 1kohm.
The Vdd are 5v,REFIN(+)=2.5V,REFIN(-)=0V.
The code is:
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,PUT//,BROWNOUT
#define ad_DI PIN_C5
#define ad_DO PIN_C4
#define ad_CLK PIN_C3
int x,y,z ;
int32 value;
void init_ad()
short int i;
output_high(ad_DI);
output_high(ad_CLK);
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16);
init_ad();
SPI_WRITE(0x3C);
while(input(PIN_C4)); //Wait for the data to be ready
value=make32(spi_read(0),spi_read(0),spi_read0));
DELAY_MS(11);
I don't undestand because in DOUT don't appears the data register. |
