Gregr Guest
PIC18F8722 CVref RF5 conflict? |
Posted: Tue Feb 21, 2006 2:20 pm |
I can not gain control of RF5 on a PIC18F8722.
ADCON1 is being set for Digital I/O after reset.
CVRCON bit 6 (CVROE) is set to zero.
Any ideas of what to check next would be appreciated!
Greg |
Posted: Tue Feb 21, 2006 2:27 pm |
1. Post a small test program that shows how you do these things.
Also show your code that uses RF5 as a digital pin. Show your
#fuses, #use, #include statements. Make it a small, but
complete program that can dropped into MPLAB and compiled.
2. Post your compiler version. |
Greg_R
Closing in on CVref Issue |
Posted: Tue Feb 21, 2006 4:41 pm |
This problem is related to "setup_vref()."
If it is set to FALSE I can control F5.
If it is set to VREF_LOW|-2 I can't set F5 high.
ADCON1 and CVROE appear to be set correctly for both cases.
Release 3.236
#include <18F8722.h>
#device ICD=TRUE
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BORV25 //Brownout reset at 2.5V
#FUSES PUT //Power Up Timer
#FUSES DEBUG //Debug mode for use with ICD
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES MCU //Microcontroller Mode
#use delay(clock=40000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)
#include "E:\SeQual\Stub1.h"
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_spi2(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_4(T4_DISABLED,0,1);
// setup_vref(FALSE);
setup_vref(VREF_LOW|-2);
setup_low_volt_detect(FALSE);
setup_oscillator(False);
input_f();
output_low(PIN_H5); //Yellow LED On
delay_ms(1500);
output_f(0xFF); //Red LED On (RF7)
delay_ms(1500);
output_f(0x00); //Red LED Off (RF7)
output_high(PIN_H5); //Yellow LED Off
delay_ms(1500);
Posted: Tue Feb 21, 2006 4:51 pm |
That line creates ASM code that configures pin F5 as an input.
To fix it, just delete that line. The CVRCON register comes
up from reset in a disabled condition. You don't need to disable
it with a line of code.
I have a question. Is that line put in by the "Wizard"
or did you put it in ? |
Greg_R
CVref |
Posted: Tue Feb 21, 2006 5:08 pm |
That line is put in by the wizard. |
Posted: Wed Feb 22, 2006 3:44 am |
I have just spent ten minutes trying the last half dozen compiler versions, and none of the wizards generate the pattern shown, for any of the Vref options. It sounds as if this may be a fairly old compiler version for this chip, which often have this sort of problem...
