I wrote and compiled a code using PCW compiler version 3.14 and worked ok. now i tryed to compile the same code using PCW compiler versione 3.242 but i've some problems:
setup_wdt(WDT_576MS);
and
setup_oscillator( OSC_4MHZ );
in last version compiler gives an error for this 2 instructions: 'Expecting an identifier' marking last bracket.
if i delete MS or MHZ compiler is ok and gives no errors.
In my .h file i find correctly both WDT_576MS and OSC_4MHZ
what is the problem??
do you think my program will be ok in case i remove those characters?
thanks
Posted: Mon Feb 20, 2006 4:47 pm
The following program compiles with no errors with PCM vs. 3.242.
