Falgellus
Serial problem after eeprom write |
Posted: Mon Feb 20, 2006 4:21 pm |
Anyone has just had a problem on serial after a write_eeprom function??
I'm using a 16f876 pic which performs a control of an automatic window open close motion. I control the micro on site or by a master pc connected to the normal serial bus. All is ok if I do not save the position of the window in the EEprom using
write_eeprom ( EPAR_SOC_POS , Position );
but if I uncomment it and begin to call it, I see a problem on the serial bus. It seems not to answer to the master calls.
The bus is controlled using an #INT_RDA interrupt.
THANK YOU FOR ANSWERS.
Paolo |
asmallri
Posted: Mon Feb 20, 2006 6:09 pm |
An EEPROM write puts the PIC to sleep for about 1 to 5ms (depending on the PIC). You may lose interrupts during this time. _________________ Regards, Andrew
Falgellus
Posted: Tue Feb 21, 2006 1:29 am |
Quote: | An EEPROM write puts the PIC to sleep for about 1 to 5ms (depending on the PIC). You may lose interrupts during this time.
Regards, Andrew |
Ok, but the serial problem arises from the write eeprom call and goes on forever after it, even if I do not call anymore the function. From that point on I cannot more communicate with the pic.
Thanks |
Posted: Tue Feb 21, 2006 1:41 am |
The UART is locking up when the receiver's buffer is overrun.
To prevent this, add the ERRORS parameter as shown below.
You'll still lose chars that aren't fetched in time, but at least
the UART won't lock up.
Quote: |
#include <16F877.H>
