Erratic SPI with 16F876A and MCP2515
iso9001
PostPosted: Sun Feb 19, 2006 10:32 pm     Reply with quote
Hi all,
I'm having some pretty big problems getting the SPI interface working. It seems I reset the 2515, read in CANCTRL and get 00, do another read and get 0x87, one more and I get 00 again. Somtimes that first 00 is an 0xFF.
I'de say maybe I'm having clock issues, but I'm using a 10MHz ceramic res with built in caps on the 2515 and a 20MHz version on the 16F876A pic. The pic seems stable. I don't have a scope of course Confused
Its REALLY frustrating.
Wondering if anyone had a similar problem or have any ideas,
Here some of the code I'm using:
void ResetMCP2515(void)
   output_high(MCP2515_CS);
   output_low(MCP2515_RESET_PIN);
   delay_us(10);
   output_high(MCP2515_RESET_PIN);
   delay_ms(0);
int ReadRegister(int regaddr)
   output_low(MCP2515_CS);
   spi_write(READCMD);
   spi_write(regaddr);
   rreg = spi_read(0);
   return(rreg);
int data=0;
int data2=0;
int data3=0;
   setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_XMIT_L_TO_H);
   ResetMCP2515();
   data3 = ReadRegister(CANCTRL);
   data2= ReadRegister(CANCTRL);
   data = ReadRegister(CANCTRL);
I've written it a few different ways. This code is borrowed from another post I saw.
Thanks in advance! [/code]
iso9001
PostPosted: Sun Feb 19, 2006 11:20 pm     Reply with quote
Here is my entire (crappy) code. Maybe there is somthing I'm missing.
Output: Which now seems to be pretty stable
Resetting CAN
Reading STAT : 80
Reading STAT : 0b
Reading STAT : 0f
Reading STAT : 03
Reading STAT : 03
Setting CTRL to 0x0F
Reading STAT : 00
Reading CTRL : 00
Program:
#include <16F876A.h>
#device ICD=TRUE
#fuses HS,NOLVP,NOWDT,NOPROTECT, PUT, NOBROWNOUT
#use rs232(DEBUGGER)
#define CS        PIN_A4
#define RESET     PIN_A3
#define READCMD   0x03
#define WRITECMD  0x02
#define CANCTRL   0x0F
#define CANSTAT   0x0E
int data=99;
int tempdata,temp;
void CANReset(void)
   output_low(RESET);
   delay_us(10);
   output_high(RESET);
void CANWrite(int addr, int value)
   output_low(CS);
   spi_write(WRITECMD);
   spi_write(addr);
   spi_write(value);
   output_high(CS);
int CANRead(int addr)
   output_low(CS);
   spi_write(READCMD);
   spi_write(addr);
   tempdata = spi_read(0);
   output_high(CS);
   return(tempdata);
output_high(CS); //Start CS high
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_XMIT_L_TO_H );
printf("Resetting CAN\n");
CANReset();
printf("Reading STAT ");
data = CANRead(CANSTAT);
printf(": %2x\n", data);
printf("Setting CTRL to 0x0F\n");
CANWrite(CANCTRL, 0x80);
delay_ms(10);
printf("Reading CTRL ");
data = CANRead(CANCTRL);
 while (1) { }
I'm very stuck.
PostPosted: Mon Feb 20, 2006 12:58 am     Reply with quote
#define CS        PIN_A4
One question to ask before looking at anything else, is do you have
a pull-up resistor on Pin A4 ?
iso9001
PostPosted: Mon Feb 20, 2006 3:08 am     Reply with quote
No,
I'm pulling it high then low then high again from the pic................
Oh sh!t ! IT GOT ME AGAIN!!!!!!!! ARRRRRRRR I AM SOOO FREAKING STUPID!!!
I H A T E THE A4 PIN!!!!
Seriously.... I'm a retarded desk rabbit !
I had it on A5 but when that was going on my code was crappy and it didn't anyway. So I moved it up one and didn't even think about it.
Thank You PCM, good catch. I'll try that tomorrow.
