KamPutty Guest
pic10f206 and delay_ms delay issue... |
Posted: Fri Feb 17, 2006 5:19 pm |
Hi all,
I'm starting a project using pic10f206's and I was getting everything setup. I got the ICD2 all connected to the pic10f206, and I can program it just fine using CCS and MPLab.
Now.....
One of my "are you working" tests is just to strobe a LED as a visual "I am working".
Now, I can turn on the LED, OFF etc. just fine.
When I use a "delay_ms" command, all hell breaks loose! In my case, it locks up (or goes to sleep/delay for a verrrrry long time!).
Here is my code:
#include <10F206.h>
#FUSES NOMCLR //Master Clear pin: disable
#FUSES NOPROTECT //Code protected from reads
#define LED PIN_B2
main()
int32 timer;
setup_comparator(NC_NC);
output_low(PIN_B0);
output_low(PIN_B1);
output_low(PIN_B2);
output_low(PIN_B3);
// delay_ms(500); // <--- uncomment this and we will *never* get below this code
while(true)
output_high(LED); // LED DOES turn on
delay_ms(500); // locked up?
output_low(LED); // never makes it here...
I've moved the "output_high's" all over the place, and I can turn on the LED, or off. I've narrowed it down to the delay_ms funtion.
I removed the #delay pragma, and the compiler complained about the delay_ms's then...
My compiler versions are: 3.234 for all 3 types.
Any thoughts???
~Kam (^8* |
KamPutty Guest
Posted: Fri Feb 17, 2006 5:32 pm |
Also, if I do not call the setup_timer_0 method, it also does not work!
#include <10F206.h>
#define LED PIN_B2
main()
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1); // <-- if this is commented, the program does not run/sleeps/halts etc
output_low(PIN_B0);
output_low(PIN_B1);
output_low(PIN_B2);
output_low(PIN_B3);
while(true)
~Kam (^8* |
Posted: Sat Feb 18, 2006 4:58 am |
First minor comment you cannot have 'output_low(PIN_B3)'. This pin is input only.
I seem to remember there was a fault on the early 10F compiler versions, that led to the configuration fuses not being set correctly. Load the file into your programmer, and check what the fuse settings are. The code is OK, _but_ I suspect you are actually getting a watchdog timeout, and hence it'll die in the first long delay.
If I remember correctly, the compiler inserts the configuration at 0x1FF, which is correct for the 10F204, but not fo the 10F206 (which requires it at 0x3FF). If you have PCW, device editor,will allow you to check/change this.
The code as posted compiles/runs OK for me on 3.234, but I may well have already changed that location.
KamPutty Guest
Posted: Sat Feb 18, 2006 10:58 am |
Thanks for the info.
but when I looked at the pic10f206 in the Device Editor, the memory config location was set to 03ff already. (BUMMER!)
Could it be something electric? Could I have wired it wrong? The only external part I am using is a 0.1uf cap from +5 and ground. Okay, I do have a res and a LED to show power, and also the res and LED that I am strobing.
But as for the pic, there is nothing other then the pic! Also, I have the ICSP connector wired (no parts other then wire!) and that is connected to the ICD2, and that all seems to work...
~Kam (^8* |
Posted: Sat Feb 18, 2006 3:37 pm |
Yes, it could very easily be a hardware issue. How much current does the LED draw?. How is the supply generated?. What is connected to the other pins?. You imply nothing. If so, put a resistor to 5v, on GP3. This pin though selected to not be 'MCLR', is still different from any other PIC pin, in having no diode protection (this is because it is aso the 'Vpp' pin, and hence has to be drivable to a higher voltage). Since it is 'input only', it is not being driven, and if it floats outside the supply rail range, it will cause the reset to operate (there is an internal diode structure here, which causes this).
KamPutty Guest
Posted: Sat Feb 18, 2006 6:20 pm |
Ttelmah wrote: | it will cause the reset to operate (there is an internal diode structure here, which causes this).
I think your summary about the reset is correct. I've been playing with it, and if I run the following program
#include <10F206.h>
#define LED PIN_B2
main()
output_low(LED);
delay_ms(16); // <--- change this
output_high(LED);
sleep();
// while(true)
// output_high(LED); // LED DOES turn on
// delay_ms(500); // locked up?
// output_low(LED); // never makes it here...
// delay_ms(500);
If the delay < 17, then LED lights.
If the delay>17, then the uP resets.
I can see the reset because at delay_ms(16), I see the LED turn OFF and then ON. The fact that I see a flicker means to me that the uP is resetting and rerunning. off/on, off/on etc.
Also, as you recommended, I did put a 10k res from gp3 to +5v., same.
The LED's I'm using are my "standard" leds, where I use a 270 ohm res with them. If memory serves right, they're drawing about 20u amps(?) each.
The power supply is my same power supply I use with everything. I think it os okay. It's a DC Regulated. 0~30V/3A.
I just did another test with this code:
#include <10F206.h>
main()
output_high(PIN_B2); // turn on LED
delay_ms(10); // lets delay.
// If commented, LED stays OFF
// if uncommented (used), LED stays ON. (Flicker)
output_low(PIN_B2); // turn off LED
while(1); // loop forever, but not sleep.
This is as basic as it gets. All I do is turn on the led, pause then turn off, then just do nothing.
Thoughts:
#1. If all goes well, the LED should NOT stay lite. The while will loop forever
#2. If the LED stays on, or flickers. Then something is resetting the uP
#3. If the delay_ms is >16 seconds, it also resets (ie. flicker).
#4. Really does sound like a watchdog timer issue
What can be resetting it?!
~Kam (^8* |
KamPutty Guest
WDT |
Posted: Sat Feb 18, 2006 6:39 pm |
I think it's something with the Watch Dog Timer. Even thought I tell it not to use it, I think it's still using it!
Here is my now WORKING code:
#include <10F206.h>
main()
setup_wdt(WDT_2304MS);
restart_wdt();
delay_ms(100); // lets delay.
restart_wdt();
I inserted the "setup_wdt(WDT_2304MS);" and "restart_wdt();" and all works.
But I want to turn it off!
~Kam (^8* |
Posted: Sun Feb 19, 2006 3:51 am |
Which is why I said early on, to load the hex file into your programmer, and see how the fuses are set in here.
If I load the generated hex, into MPLAB (7.1), it shows the WDOG as off, but the code protect as on!. However it shows the configuration bytes as being at 0x1FF, which is incorrect for the 10F206!... If I load it into MachX, it correctly shows WDOG off, code protect off, and MCLR selected as an input. The fault here is in MPLAB, not in CCS, which is treating the configuration words as if they should be at address 0x1FF, and will program them incorrectly. Your programmer may have the same fault...
I suspect 7.2, will fix this.
KamPutty Guest
Posted: Sun Feb 19, 2006 10:59 am |
Ttelmah wrote: | Which is why I said early on, to load the hex file into your programmer, and see how the fuses are set in here.
Ahhhh! I'm gonna kill myself!
My version of MPLab is 7.3, and it shows in the Config->Configuration Bits menu the following!
Address: 0fff, Value: 0fff, Category: Watchdog Timer, Setting: ON
Address: , Value: , Category: Master Clear Enabled, Setting: Enabled
Address: , Value: , Category: Code Protect, Setting: OFF
No matter what I do with the fuses, I cannot get it to change, assuming that Config->Configuration Bits is the correct way to check.
~Kam (^8* |
Stuckeymax
Posted: Tue Feb 27, 2007 2:01 pm |
I found something goofy in the compiler's comparator setup. I had an issue with pins misbehaving, and the processor locking up in an infinte, self-reset loop on startup (but not always; only when Vdd rise time was fast). I replaced set_comparator C instructions (and some other setup stuff) with assembly and the problem went away. Code: |
#asm
clrwdt ; // This shouldn't be necessary, but...
movwf OSCCAL ; // Calibrate the oscillator bits 7 through 1
bcf OSCCAL,0 ; // Disable Fosc/4 output to GPIO 2 by clearing bit 0
movlw 0b11110011 ; // Disable the comparator
movwf CMCON0 ; // 7 6 5 4 3 2 1 0
; // CMPOUTX COUTEN/No POL/no T0CS hot CMPoff IntRef RefSelX CWU Off
; // X 1 X 1 0 X X 1
; // not OK OFF OK
movlw 0b11000010 ; // Setup TMR0 for internal clock, with 1:8 prescale
option ; // No WUoC; No WPU013; TMR0 Int Clk; T0CKI edge; PSA to TMR0; 1:8
clrf GPIO ; // Zero out the port prior to configuring GPIO
movlw 0b00001000 ; // Set GPIO DDR bits in/out/out/out
tris GPIO ; // Stuff the literal
#endasm |
