Every character is seen as acsII .......why??
Kauty
PostPosted: Fri Feb 17, 2006 12:11 pm     Reply with quote
Hi all,
Is it me or is this just annoying and very silly.
I am trying to output hex values out the serial pins. sounds simple.
so i am using printf or fprintf to do so:
one would thing if you typed :
for(i=0x0;i<0x7F;i++){
printf("%x",i);
delay_ms(300);
i was thinking, this will give me the hex value of the numbers 0-128 on the serial TX line. instead it is giving me hex values of 30-7F, becuase it treats variable i as an ascii character......is that normal to anyone?? or i am alittle oblivious about something.
I will appreciate any help
PostPosted: Fri Feb 17, 2006 12:40 pm     Reply with quote
You are I think misunderstanding something.
Hex, _is_ an ASCII format. The number '7F',is the two ASCII characters '37', and '46'. It sounds as if you are running a program at the other end, which is taking raw binary, and turning this into it's hex representation. hence your value gets converted twice!.
Try outputing the character using putc, as:
    putc(,i);
    delay_ms(300);
This sends the raw value, and your program at the other end, will then do the required conversion.
In fact you are only dealing with raw numbers, and hex need not come into it at all. So:
for(i=0x0;i<127;i++){
    putc(,i);
    delay_ms(300);
Will give exactly the same result...
kauty
PostPosted: Fri Feb 17, 2006 12:53 pm     Reply with quote
You would trhink after those year i would have it striaght!
You are absolutely correct and thanks for your quick help
