graphic lcd problems with pic18f4455
DriverInside
PostPosted: Fri Feb 10, 2006 7:37 am     Reply with quote
I'm using a BLG1206A1YSR with HD61202U chipset. I tested it with a pic16f877 using ex_glcd.c and it worked fine.
I tested with the 4455, the display doesn't works. The port i'am using works good, i have tested it.
Does someone know if have I something to change in the driver (*.c) to fix that problem ??
thx
JP
.... sorry for my english :(
PostPosted: Fri Feb 10, 2006 4:32 pm     Reply with quote
It could be that Port B is not being set to all digital i/o pins by
the CCS startup code in your version.
What version is your PCH compiler ?
You can find the version at the top of the .LST file. This file
is in your project folder.
PostPosted: Mon Feb 13, 2006 7:33 am     Reply with quote
i'm using CCS PCM C Compiler, Version 3.224, 26926
that's working fine this way with 16f877 :
LCD Pin connections:
* 1: VSS is connected to GND
* 2: VDD is connected to +5V
* 3: V0 - LCD operating voltage (Constrast adjustment)
* 4: D/I - Data or Instruction is connected to B2
* 5: R/W - Read or Write is connected to B4
* 6: Enable is connected to B5
*7-14: Data Bus 0 to 7 is connected to port D
*15: Chip Select 1 is connected to B0
*16: Chip Select 2 is connected to B1
*17: Reset is connected to C0
*18: Negative voltage is also connected to the 10k Ohm POT
*19: Positive voltage for LED backlight is connected to +5V (N/C)
*20: Negavtive voltage for LED backlight is connected to GND (N/C)
but I would like to use it this way :
* 4: D/I - Data or Instruction is connected to A2
* 5: R/W - Read or Write is connected to A4
* 6: Enable is connected to A5
*7-14: Data Bus 0 to 7 is connected to port B
*15: Chip Select 1 is connected to A0
*16: Chip Select 2 is connected to A1
the probleme with this configuration is that only one side of the display is working.
treitmey
PostPosted: Mon Feb 13, 2006 11:22 am     Reply with quote
Did you define port A as digital?
DriverInside
PostPosted: Mon Feb 13, 2006 3:23 pm     Reply with quote
i did cause for now i dont need analog:
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
set_adc_channel(0);
but how can I define port A as digital?
this is really a pain right now :(
thank for your help...
PostPosted: Mon Feb 13, 2006 3:40 pm     Reply with quote
You did it with the statement above.
Also check these things:
1. Do you have a pull-up resistor on Pin A4 ?
If not, add a 4.7K pull-up.
2. Do you have the NOLVP parameter in your #fuses statement ?
If not, add it.
PostPosted: Mon Feb 13, 2006 4:37 pm     Reply with quote
yep, I have a pull-up on A4 and I also have NOLVP in my #fuses statement.
Do I have to activate the internal pull-up on port b ??
thx again
PostPosted: Mon Feb 13, 2006 4:56 pm     Reply with quote
the problem with this configuration is that only one side of the display is working
If only one side is working, then look closely at the connections for
the CS1 and CS2 signals.
DriverInside
PostPosted: Tue Feb 14, 2006 7:18 am     Reply with quote
thx you !! I fix it!!
