| Ttelmah Guest
				|  Posted: Mon Feb 13, 2006 10:19 am |   |
				| Yes, and no... The code generated to handle a stream, is 'hardwired', to the I/O bit used. So you cannot use a variable to transfer it, and gain anything. The code has to exist seperately for each stream. However there is nothing to stop you from passing the name to a function, and then use a switch statement to select the required routine. The names can be passed as an int8 variable, so:
  	  | Code: |  	  | void fn(int8 chr,int8 stream) {
 switch (stream) {
 case hard :
 fputc(chr,hard);
 case soft :
 fputc(chr,soft);
 With streams called 'hard', and 'soft', will allow you to send characters to a named stream.
