PS2 KEYBOARD
PS2 KEYBOARD
PostPosted: Thu Feb 09, 2006 7:39 pm     Reply with quote
Hy !
I looking to find a sample source to send key to PC PS2 port
I only need to detect keypress on pic port and send A key on PC
Alain
RVaughn13
PS2 Keyboard
PostPosted: Fri Feb 10, 2006 6:18 pm     Reply with quote
There are other ways to pass information to your PS2 port (if you only want to detect a button press or switch closure). There are many different types of PS2 keyboard emulators used by the MAME gaming industry. These emulators have screw-lug terminal blocks and are programmable to transmit any character (or series of characters) to your IBM PS2 keyboard port. An example can be found here:
http://www.ultimarc.com/ipac1.html
Hope this helps!
--Rick
Donlaser
PostPosted: Fri Feb 10, 2006 8:07 pm     Reply with quote
I use this routines for ps/2 i/o, with a pic16f628 running @4mhz intrc.
Work without problem in more than 2000 units deployed.
You can use this for code as Asm inline o recode in CCS C.
KBD_CLK_I and KBD_DAT_I are inputs pins
KBD_CLK_O and KBD_DAT_O are outputs pins what drives a npn transistors with the colectors conected at de data lines/clock lines and the emiter to GND.
note: Delay is in "cycles" (running at 4mhz).
I hope this was a start point for you.
Hernan.
Argentina.
; ByteOut:
; Sends a byte in w to the host.
; Returns 0xFE if inhibited during transmission.
; Returns 0xFF if host interrupts to send its own data.
; Returns 0x00 if byte sent successfully.
; OUTPUT ONE BYTE: - TIMING IS CRITICAL!!!
SendKey movwf LastSend
ByteOut movwf Temp0
InhibitLoop btfss KBD_CLK_I ;Test for inhibit
goto InhibitLoop
Delay 50
btfss KBD_CLK_I
goto InhibitLoop
btfss KBD_DAT_I ;Check for request-to-send
retlw 0xFF
clrf Parity
movlw 0x08
movwf Counter
movlw 0x00
call BitOut ;Start bit (0)
goto ByteOutEnd
Delay 4
ByteOutLoop movf Temp0, w
xorwf Parity, f
call BitOut ;Data bits
goto ByteOutEnd
rrf Temp0, f
decfsz Counter, f
goto ByteOutLoop
Delay 2
comf Parity, w
call BitOut ;Parity bit
goto ByteOutEnd
Delay 5
movlw 0xFF
call BitOut ;Stop bit (1)
Delay 48
retlw 0x00
ByteOutEnd bcf KBD_DAT_O ; dato a alto (inv)
nop ; x las dudas...
bcf KBD_CLK_O ; clock a alto (inv)
retlw 0xFE
BitOut andlw 0x01 ; saca el bit 0 de w por la salida..
btfss STATUS, Z
bcf KBD_DAT_O ; cero
btfsc STATUS, Z
bsf KBD_DAT_O ; uno
Delay 21
bsf KBD_CLK_O ; clock abajo (uno)
Delay 45
bcf KBD_CLK_O ; clock arriba (cero)
Delay 5
return
; ByteIn:
; Reads a byte from the host.
; Result in "Receive" register.
; Returns 0xFD in w if timeout waiting start bir
; Returns 0xFE in w if host aborts transmission.
; Returns 0xFF in w if framing/Parity error detected.
; Returns 0x00 in w if byte Received successfully.
; READ ONE BYTE: - TIMING IS CRITICAL!!!
ByteIn clrf Contador
ByteInL decfsz Contador, F
goto espsb
retlw 0xFD
espsb btfss KBD_CLK_I ;Wait for start bit, clock alto con dato bajo..... por el tiempo en Contador...
goto ByteInL
btfsc KBD_DAT_I
goto ByteInL
movlw 0x08
movwf Counter
clrf Parity
Delay 28
ByteInLoop call BitIn ;Data bits
retlw 0xFE
bcf STATUS, C
rrf Receive, f
iorwf Receive, f
xorwf Parity, f
decfsz Counter, f
goto ByteInLoop
Delay 1
call BitIn ;Parity bit
retlw 0xFE
xorwf Parity, f
Delay 5
ByteInLoop1 Delay 1
call BitIn ;Stop bit
retlw 0xFE
xorlw 0x00
btfsc STATUS, Z
clrf Parity
btfsc STATUS, Z ;Stop bit = 1?
goto ByteInLoop1 ; No--keep clocking.
;Acknowledge
bsf KBD_DAT_O ; dato como salida
Delay 11
bsf KBD_CLK_O ; clock como salida
Delay 45
bcf KBD_CLK_O ; clock como entrada
Delay 7
bcf KBD_DAT_O ; data como entrada
btfss Parity, 7 ;Parity correct?
retlw 0xFF ; No--return error
Delay 45
retlw 0x00
BitIn Delay 8
Delay 45
Delay 21
btfsc KBD_DAT_I
retlw 0x80
retlw 0x00
PostPosted: Sat Feb 11, 2006 9:08 am     Reply with quote
Thank you very much !!
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Mon Feb 13, 2006 2:16 am     Reply with quote
Just came across this one:
http://www.ccsinfo.com/forum/viewtopic.php?t=25673
