Urgently in need of help!
[terminate]
PostPosted: Sun Feb 12, 2006 8:47 pm     Reply with quote
I'm having trouble with the ADC.. I've read all the previous posts about it and tried their solutions but I can't get it to work..
Heres my code:
#include <18F452.h>
#device ADC=8;
#fuses XT,NOWDT,NOPROTECT,NOLVP
#define INTS_PER_SECOND 76     // (20000000/(4*256*256))
int ir_value1=0;
/* #int_rtcc                          // This function is called every time
void clock_isr() {                 // the RTCC (timer0) overflows (255->0).
                                   // For this program this is apx 76 times
                                  // per second.
      ir_value1=Read_ADC();
      delay_us(20);
void init_adc(void);
void init_pwm(void);
void init(void);
void main(void);
void forward(void);
void speed(int x1,x2);
void init_adc(void)
  setup_adc(ADC_CLOCK_INTERNAL );
  setup_adc_ports(ALL_ANALOG);
  set_adc_channel(5); //maybe use this when you read it because, im using 2 channels also need a delay_us(20) to change channels
  delay_us(20);
void init_pwm(void)
  setup_ccp1(CCP_PWM);
  setup_ccp2(CCP_PWM);
  setup_timer_2(T2_DIV_BY_1,255,1);
  set_pwm1_duty(0);
  set_pwm1_duty(0);
void init(void)
  init_pwm();
  enable_interrupts(INT_RTCC);
  init_adc();
  set_tris_a(0b11111111);
  set_tris_c(0b00000000);
  set_tris_b(0b00000000);
void forward(void)
  output_high(PIN_C6);
  output_high(PIN_C5);
void speed(int x1, x2)
  set_pwm1_duty(x1); // need to compensate for straight movement
  set_pwm2_duty(x2);
  init();
  speed(200,200);
  while (true)
      forward();
      output_low(PIN_B7);
      if (ir_value1=Read_ADC() > 4) {
        output_high(PIN_B7);
I'm trying to read in the input of a sharp 38khz sensor which outputs 0 to 5 volts, but that is aside from the problem. The problem I'm having is that when i start the device, the pin and b7 blinks.. even with no value on the channel (ie the sensor is disconnected). I've tried it with it connected with 0 volts across the sensor, but the same thing happens. I've measured the impedance to be about 6 kohms, which exceeds that of the 2.5 in the documents, but I've tried disconnecting the sensor but it still fails to be zero. What could be wrong and how can I fix it?
PostPosted: Sun Feb 12, 2006 9:02 pm     Reply with quote
Look at your code. Do you see anything wrong with the line in bold:
while (true)
forward();
output_low(PIN_B7);
[terminate]
PostPosted: Sun Feb 12, 2006 9:19 pm     Reply with quote
hmmm yeah theres an error there,
i've changed it to this:
while (true)
      forward();
      output_low(PIN_B7);
      ir_value1=read_adc();
      if (ir_value1 >= 4) {
but it still doesn't work... even with the sensor disconnected i get the flashing of the LED
[terminate]
PostPosted: Sun Feb 12, 2006 10:14 pm     Reply with quote
please dont tell me this is because i'm trying to compare a 8 bit number against a number 4 which is almost true even when its close to 0
and so 4 volts would be like 200 instead of just 4
PostPosted: Sun Feb 12, 2006 10:42 pm     Reply with quote
You're comparing "ir_value1" to 4. So any value from 4 through 255
will cause the LED to blink. The A/D input may reach a value of 4
just due to noise. It's no surprise that it blinks.
If the connector is disconnected then you have a floating input.
It can float to any value. Since a value from 4 to 255 will cause
blinking, again it's no surprise that it blinks.
Also, I notice you're using B7. Pin B7 is used by the CCS debugger
and the Microchip ICD2 debugger. If you're using one of those units,
then please change your LED pin to another pin (Besides B6 and B7).
[terminate]
PostPosted: Sun Feb 12, 2006 11:04 pm     Reply with quote
thank you so much PCM programmer!
i wish you could be my mentor!
what i initially thought was that ir_value1 was being compared to 4 volts... stupid me... i wasnt thinking 4 in binary
