jds-pic (DMC-50747NF-AK)
PostPosted: Tue Feb 07, 2006 2:03 pm     Reply with quote
Hi jds-pic, a few months ago you posted
a message about the DMC-50747NF-AK,
do you know the part namber of the
24 pin connector ( digikey, mouse,...)
newguy
PostPosted: Tue Feb 07, 2006 2:26 pm     Reply with quote
I'm not 100% sure about it, but that LCD has a 24 pin connector and it looks like it has a 1 mm pitch.
If you have the current digikey catalog, look at pages 58 and 60. Part numbers are: HFC24CT-ND and WM7685CT-ND.
Hope this helps.
PostPosted: Thu Feb 09, 2006 8:39 am     Reply with quote
You are right, the pitch is 1mm
Ill buy some connectors
Thank you
jds-pic
PostPosted: Thu Feb 09, 2006 10:51 am     Reply with quote
it seems you are on your way already. good.
ps... here is the driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=19521
jds-pic
