A simple C question....
[mAnNaRo]
PostPosted: Thu Feb 09, 2006 3:53 am     Reply with quote
// Clear external EEPROM memory
void clear_MEMORY(void) {
   int32 mem_address;
   for (mem_address = 0; mem_address <= 0xFFFF; mem_address++) {
      write_ext_eeprom(mem_address, 0x00);
How can I save RAM memory using an int16 for mem_address counter instead of int32? With int16 the compiler tell me that the condition is always TRUE (that's true). When I increment an int16 variable 0xFFFF I get a rollover to zero?
Thanx
Alex
Roebi
The Solution-Code
PostPosted: Thu Feb 09, 2006 4:28 am     Reply with quote
What about this:
   int16 mem_address = 0;
   do {
     write_ext_eeprom(mem_address, 0);
     mem_address++;
   } while (mem_address);
} // clear_MEMORY
Best regards
Roebi
jds-pic
Re: The Solution-Code
PostPosted: Thu Feb 09, 2006 10:57 am     Reply with quote
Roebi wrote:
What about this:
   do {
     mem_address++;
} // clear_MEMORY
since you are doing bytewise writing to the eeprom, you can save yourself a lot of time clearing the memory by doing a read first, and only writing a zero if the read value is nonzero. for even a small eeprom this will probably cut lots of "long" 10ms writes out of the picture.
   do {
     if !(read_ext_eeprom(mem_address)) {
       mem_address++;
} // clear_MEMORY
