strcpy vs strncpy
Eugeneo
strcpy vs strncpy
PostPosted: Wed Feb 08, 2006 11:08 pm     Reply with quote
The first example doesn't work, the second does. What am I doning wrong?
char data_string[40];
char data_input[40];
data_input[0]='A';
data_input[1]='B';
data_input[2]='C';
data_input[C]=0;
strcpy(data_string,data_input);
printf(data_string);
But nothing is stored in data_string, but I found a work-around.
data_input[0]='A';
data_input[1]='B';
data_input[2]='C';
data_input[C]=0;
strncpy(data_string,data_input,40);
This works. What am I doing wrong?
kel
try
PostPosted: Wed Feb 08, 2006 11:14 pm     Reply with quote
try this...
printf("%s",data_string);
Eugeneo
PostPosted: Wed Feb 08, 2006 11:31 pm     Reply with quote
I used the printf to debug the code. There was a problem with my string copy before I inserted the printf.
kel
Is this part of the string!!
PostPosted: Wed Feb 08, 2006 11:38 pm     Reply with quote
Check this below.You are using the array wrongly i guess!!check this
data_input[C]=0;
why do you have C as an index.did you define it some where else?
if not change it to 3 i.e.
data_input[3]=0;
PostPosted: Wed Feb 08, 2006 11:39 pm     Reply with quote
1. What PIC are you using ?
2. What is your compiler version ?
Eugeneo
Re: Is this part of the string!!
PostPosted: Wed Feb 08, 2006 11:48 pm     Reply with quote
data_input[C]=0;
data_input[3]=0;
Sorry.. It was right in the original.
Compiler: 3.227
Chip: 16F877
Eugeneo
PostPosted: Wed Feb 08, 2006 11:53 pm     Reply with quote
I noticed there was a fix for the 18F, but I guess it was always working for the 16F?
PostPosted: Thu Feb 09, 2006 12:05 am     Reply with quote
I tested the following program with PCM vs. 3.227 and it displayed this:
ABC
#include <16F877.H>
data_input[0]='A';
data_input[1]='B';
data_input[2]='C';
data_input[3]=0;
strcpy(data_string, data_input);
PostPosted: Thu Feb 09, 2006 12:12 am     Reply with quote
I didn't see your statement above, initially.
So I made a new test program in which printf() is commented out and
stepped through it with the simulator. The values are in there.
I saw 0x41, 0x42, 0x43 go into 'c' in the watch window, as I stepped
through the code.
#include <16F877.H>
char c;
data_input[0]='A';
data_input[1]='B';
data_input[2]='C';
data_input[3]=0;
//printf(data_string);
c = data_string[0];
c = data_string[1];
c = data_string[2];
c = data_string[3];
Eugeneo
PostPosted: Thu Feb 09, 2006 2:26 am     Reply with quote
I've tested it again, and it doesn't work. This is the code I get
008     PSP_DATA
015     CCP_1_LOW
015-016 CCP_1
016     CCP_1_HIGH
01B     CCP_2_LOW
01B-01C CCP_2
01C     CCP_2_HIGH
020     strtok.save
021-024 _Randseed
025-04C data_string
04D-074 data_input
075     rs232_errors
077     @SCRATCH
078     @SCRATCH
078     _RETURN_
079     @SCRATCH
07A     @SCRATCH
07B     @SCRATCH
07C     main.@SCRATCH
07D     @delay_ms1.P1
07D     main.@SCRATCH
07E     main.@SCRATCH
.................... data_input[0]='A';
002F:  MOVLW  41
0030:  MOVWF  4D
.................... data_input[1]='B';
0031:  MOVLW  42
0032:  MOVWF  4E
.................... data_input[2]='C';
0033:  MOVLW  43
0034:  MOVWF  4F
.................... data_input[3]=0;
0035:  CLRF   50
.................... strcpy(data_string, data_input);
0036:  MOVLW  4D
0037:  MOVWF  10
0038:  MOVLW  25
0039:  MOVWF  7C
003A:  MOVF   10,W     W=4D
003B:  MOVWF  04       FSR=4D
003C:  MOVF   00,W
003D:  MOVWF  7E       7E ='A'
003E:  MOVF   7C,W
003F:  MOVWF  04       FSR=25
0040:  MOVF   7E,W     W='A'
0041:  MOVWF  00       REG 25='A'
0042:  MOVF   00,F     Test reg
0043:  BTFSC  03.2     Zero bit
0044:  GOTO   048      Zero END
0045:  INCF   7C,F
0046:  INCF   7D,F     Should this not be 10?
0047:  GOTO   03A      Loop
.................... printf("%s\n\r",data_input);
0048:  MOVLW  4D
0049:  MOVWF  04
004A:  MOVLW  00
004B:  IORWF  00,W
004C:  BTFSC  03.2
004D:  GOTO   054
004E:  BTFSS  0C.4
004F:  GOTO   04E
0050:  MOVF   00,W
0051:  MOVWF  19
0052:  INCF   04,F
0053:  GOTO   04A
0054:  MOVLW  0A
0055:  BTFSS  0C.4
0056:  GOTO   055
0057:  MOVWF  19
0058:  MOVLW  0D
0059:  BTFSS  0C.4
005A:  GOTO   059
005B:  MOVWF  19
.................... printf("%s\n\r",data_string);
005C:  MOVLW  25
005D:  MOVWF  04
005E:  MOVLW  00
005F:  IORWF  00,W
0060:  BTFSC  03.2
0061:  GOTO   068
0062:  BTFSS  0C.4
0063:  GOTO   062
0064:  MOVF   00,W
0065:  MOVWF  19
0066:  INCF   04,F
0067:  GOTO   05E
0068:  MOVLW  0A
0069:  BTFSS  0C.4
006A:  GOTO   069
006B:  MOVWF  19
006C:  MOVLW  0D
006D:  BTFSS  0C.4
006E:  GOTO   06D
006F:  MOVWF  19
PostPosted: Thu Feb 09, 2006 12:16 pm     Reply with quote
I've installed your version, and I've gone back to vs. 3.188 as well,
and I don't see the bug. The address that you're getting, which is
0x10, is not even listed in your symbol table. Can you confirm that
your version is 3.227 ? The version is given at the top of the .LST file.
Also, can you re-install your compiler ? Something is very wrong,
and I think you should re-install it.
